AH FabricationsVolks Autos
Results 1 to 16 of 16
    Aug 2007
    87
    Snapped Spring, suspension options?
    Have a snapped rear spring on the A4, thinking its a good time to lower the car. What are my options? And anyone got suggestions on good places to buy suspension? Car is a A4 2.8 Quattro, 1999.
    -scrupes-'s Avatar
    Dec 2008
    North East
    14
    I got a set of Weitec springs and shox of Damian @DPM ( see sponsors on main page) very nice ride and looked loads better with being lowered -35mm there is also a -45mm option but i like a bit more clearance for covering rough ground when out shooting and fishing so i went -35mm. The shox are matched to the springs so you dont get the problems of bottoming out as you would with lowering on the standard springs but as i got some useless fecker in a garage to fit them and they ballesed it up i've just been getting round to changing the shockers to Bilstein b6 sports which are much firmer and a bit more bumpy on rough roads.
    I'd recomend the weitec kit though if you dont wanna spend a fortune IIRC 400 all in. whereas i've just paid 470 for the Bilstein shockers alone :eek:
    WANTED: A pair of S3 / TT caliper carriers for a 312mm upgrade job
    ALSO: looking for a MILLTEK V6 system to fit a B5 chassis
    PM me if you have anything like these for sale please!!
    PAUL
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,317
    Eibachs Pro-Kit gets my vote.
    We recently fitted an eibach pro-kit and bilstein B6 shocks to my bros S4 and i'm very impressed. Its not harsh at all, just the right amount of lowering and all round spot on quality.
    You say you paid 470 for those B6 shockers, Siena got craig a set for just over 300, so you were ripped a new one there mate...
    Think the springs were 150ish, and while expensive they're amongst the best out there, and certainly worth it imo.
    TD5 Land Rover Defender build
    Aug 2007
    87
    been told eibach are very good. can i just get springs on my standard dampers?
    ALPINE's Avatar
    Yes its diesel, now cry u lost
    Apr 2008
    S/E LONDON / KENT
    3,086
    fk coilovers all day long!
    look like that badboy \/ \/ \/ \/ \/
    Now to many mods to list! Lots of power, torque and Leather!
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,505
    FK's are good. I had Eibachs once and was dissapointed with the drop, the ride was ok but on Prokit springs i found a drop of 20mm max even after settling.
    I wouldnt stick springs on your shocks mate, you WILL regret that, the car will look better but ride poorly as the shock will not be able to control the springs as the rate of the spring is increased
    "Stick a V8 in it!"
    15,317
    The drop isnt into the weeds, but imo its just right to give the car a lower stance while optimising the handling, any lower and you start to get negative effects, which is the point of the pro-kit. The Sportline kit they do is lower, but clearly its not going to handle as nicely.
    As for running them on stock dampers, i'd think that as a temporary measure they'd be ok, although i'd be looking at swapping them out for something else, especially if the OE dampers have done any more than about 60-70k as they will be past their best by then...
    Aug 2007
    87
    where can i get fk coilovers?
    "Stick a V8 in it!"
    15,317
    I wouldnt be fitting cheap coilovers to my car.
    Any performance parts place like many of the folks that advertise on here should be able to supply them.
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    vmax coilovers seem to be getting good reviews as an altenative to weitec gts
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,841
    Here my old 2.8 Quattro on 18" & 17" rim with H&R Race springs
    Jul 2007
    Essex
    400
    Go get your self some sensible springs mate, you know the old skool ford rule, you can get away with 25mm - 30mm on std shocks anymore then your asking for trouble.
    Ming Blue A4 B5 RS4 Replica (SOLD)
    T28 Kit (SOLD)
    Aug 2007
    87
    looking on the eibach site and there are 2 pro spring kits listed for my car, one says including auto and one says excluding auto. Bit odd?
    "Stick a V8 in it!"
    15,317
    auto gearbox weighs slightly more, which means you need slightly different spring rates, something that most aftermarket springs dont bother with.
    Aug 2007
    87
    ah ok, so i will be fine with the eibach ones exc auto box then. will get those ordered, cheers for the advice!
    "Stick a V8 in it!"
    15,317
    no worries, i'm sure you'll be pleased with them! Need to get some pics once they're on!
