EM TuningMonster Motorsport
    Dave DND's Avatar
    DND Services Ltd
    Dec 2008
    Paignton, UK
    50
    1999 A4 Avant Boot light switch
    Hi guys, newbie here, and apologies if this has been asked before, but I couldn`t find the answer if it was.
    The boot light in my Avant does not work when the tailgate is opened, but does switch on when you slide the switch at the light, so power is going to it. My initial thoughts are that a boot switch has gummed up, or a cable has fatigued somewhere.
    To save endless hours searching, has anyone got any pointers for me please? Not even sure where the switch is ?
    Regards
    Dave
    Radio & Decoding Technician
    In Car Audio Service Department
    DND Services Ltd
    Paignton
    01803-391680
    www.dndservices.co.uk
    www.instant-radio-codes.com
    My Daily Hack is a 1999 A4 Avant 2.4 SE V6 Auto
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    switch is built in to lock mechanism, mine failed and i found a replacement in scrappy, but im not sure if switch can be replaced on its own
    Aug 2008
    148
    switch is located on the catch and can't be replaced only as whole unit, did a b6 on friday new catch about the 25 quid mark, but first check its not the wires between the tailgate and the body and does your rear wash work properly? common fault is pipe pops off leaks onto switch then corrodes it. if it is the lock always check the pipe where it goes into the motor and i always put a couple of tywraps on to stop the pipe poping off, usually if the nozzle freezes
    Dave DND's Avatar
    DND Services Ltd
    Dec 2008
    Paignton, UK
    50
    Thanks guys - a good head start
    Regards
    Dave
    DND Services Ltd
    Paignton
    01803-391680
    Jan 2007
    Berkshire
    40
    Did you manage to find what was wrong? i have the same problem on my A6 Avant...
    Audi A6 Avant 1.9Tdi Sport
    Audi A4 convertible 2.0T FSI S-Line
    Dave DND's Avatar
    DND Services Ltd
    Dec 2008
    Paignton, UK
    50
    Yes, it was the boot catch itself - I removed mine, flooded it with WD40 and then blew it around with an airline - seems to have worked ever since.
    I cannot see a way to get the switch out though, as it appears that the two halves of the catch are riveted together - if it fails again, it will be a trip to the parts dept I think.
    Regards
    Dave
    DND Services Ltd
    Paignton
    01803-391680
