Results 1 to 11 of 11
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    Alarm Honk when Arming
    So my '96 toots its horn when you lock the car. Its quite useful in that it lets you know all the doors are properly closed and the alarm is active.
    Craig's 98 S4 however doesn't do it. It just locks, and a silly light comes on in the door card, it might also flash its indicators but thats not always visable.
    I've had a look around and come across this: http://www.ross-tech.com/vag-com/cars/audiB5.html which seems to suggest theres an adaption setting to REMOVE the honk (ie -1024 off the adaption value thats currently there...) however i dont know if i can do the opposite to add the honk?
    Anyone tried this and had any success?
    TD5 Land Rover Defender build
    Oct 2007
    2,597
    Aragorn, a lot of later cars had the horn deleted, though as Craigs car's a pre-facelift, I'm not sure if his is affected.
    Have you taken a look at the horn in the n/s rear panel?
    Early cars had the visual "armed" state show as a LED in the hazard lamp switch, later ones of course, had the LED's in the door cards, by the lock pins.
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,065
    i recoded mine to honk, dreadfull sound hated it so removed it again, but should work if you try it
    "Stick a V8 in it!"
    14,900
    His has the lights in the door cards, but its just not as good an indicator that a toot from the horn.
    I'll take a look in the rear quarter to see if the horn is there, could it be there but be faulty?
    I think i'll try recoding it then? Did you just add 1024 to whatever value was there already?
    Fraser's Avatar
    Aug 2003
    the north
    586
    35-Central Locks: -- KWP-1281
    VAG-COM Works fine (note: pre-'97 A4's may not have this module).
    Recode locking options
    [Select]
    [35 - Cent. Locks]
    [Recode - 07]
    Enter the coding below
    [Do It!]
    Write down the existing coding for future reference.
    A4 pre-1998 with Delta radio and anti-theft system
    Standard Coding: 03468
    A4 pre-1998 with Delta radio, anti-theft system and keyless entry
    Standard Coding: 12172
    A4 1998+ with Concert/Symphony radio and anti-theft system
    Standard Coding: 03340
    S4, A4 1998+ with Concert/Symphony radio, anti-theft system and keyless entry
    Standard Coding: 16140
    Add the following options to your coding number:
    +64 Windows up, sunroof close, and windows down with remote.
    -04 One touch unlock of all 4 doors and trunk
    -1024 Remove horn honk when arming
    +32 Auto lock/unlock of doors (Doors lock at 15 mph and unlock when key is removed)
    So, if you want to have a 1999 A4 with Concert radio and anti-theft system and keyless entry, and you want to add window control with the remote along with auto-lock, then:
    add 03340+64+32= 03436
    "Stick a V8 in it!"
    14,900
    ye i linked to that above? but it says -1024 to remove honk and doesnt mention adding honk...
    i'm guessing +1024 will add honk so i'll give that a try.
    jcb
    Sep 2005
    uk
    4,070
    glad mine doesnt honk. goes against my stealthy nature!
    on another note, I see you have listed a code for closing windows when it locks.
    I can do this by holding the lock button down but does your code close windows with just one click as you would for normal locking?
    Jul 2008
    Birmingham
    629
    My '96 honks. Mine has electrical gremlins operating the alarm though, so move along, nothing to see here...
    A4 1.8TQS
    stapo69's Avatar
    All hail the mighty quattro!
    Mar 2007
    966
    My 98 S4 didn't honk, but now it does by using vagcom, although i wanna get round to turning it off, it is one pathetic little horn!
    MRC-Powerflex-Hotchkis-Porsche-Compomtive-Vredestein-034-JHM-Apikol-EBC-FK-Labree-Vibrant-Recaro
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    Bridgend, South Wales
    614
    Quote Originally Posted by jcb View Post
    No, you need to keep the remote button pressed until the windows/sunroof are closed...........
    I've re-programmed mine to have all the convenience features (horn honk on arming / remote closure of windows and sunroof and autolocking) and wouldn't be without them now.
    The standard factory setting of the indicators flashing when arming the alarm is lousy IMHO, I was forever double-checking to see if I'd actually locked the car......
    The alarm-setting honk may sound a bit weedy but at least gives an audible confirmation that all the doors are securely closed and the darn thing is locked/alarmed..............
    '99 Ming Blue A4 Avant TDi SE 110 + Dragon Performance Tuning Box
    Factory sunroof / Cruise / Aircon + Climate / Royale Blue leather
    '72 1302LS Karmann Beetle Cabrio Silbermetallic
    '63 Karmann Ghia Sunroof Coupe Pacific Blue
    "Stick a V8 in it!"
    14,900
    nessy: exactly, craigs always double checking the cars locked after pressing the button, an audiable notification is much easier to notice.
    It is a small niggle, but its one of those annoying things having to keep looking back at the car to ensure it did actually lock.
    I'll give it a bash with vagcom and see if it works!
