Monster MotorsportChris Nott
Results 1 to 7 of 7
    S4_dan's Avatar
    Fire up the Quattro!
    Jan 2006
    1,599
    Urgent help required please.....
    Hi all,
    I'm currently away from home and this morning i moved my 1.8T sport forward about 10yards, the car started fine with no problems, nor has there been anything to get suspicious about whilst starting the car. Yet I've just gone to move my car back and there is nothing!?!?! THe car battery has good charge, all the lights work and they don't even dim at all when i turn the key!
    THere is no clicking of the solenoid or any relays and the starter motor doesn't even attemp to turn.
    i've tried rocking the car in gear and tapping the starter through the small hole i can see it behind the turbo.
    any other suggestions please?
    vag-com doesnt bring up any faults other than my abs sensors on the rear but they have always come up.
    the fuel light is on and the mileage went from 5 to 0 miles just from moving the car by hand from a slight slope to level ground. the fuel gauge does move a bit so its not completely empty and cant see how that would prevent the car from attempting to start.
    thanks in advance.
    dan
    2002 2.5 V6 Quattro
    Oct 2007
    2,597
    It sounds like either of 2 things:
    1) Starter motor fault.
    2) Igbition switch fault.
    I'd be inclined to go with a faulty ignition switch, quite a common fault.
    At least, you can get a bump start, to get you home, then look further into the problem in daylight.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    If it was the ignition switch, it should be easy enough to remove the steering wheel cowling and run a test lead between the big live and the starter solenoid feed on the back of the ignition switch to get it started without the effort of bumpstarting... I'm not sure what colors you should be looking for but i can find out if need be...
    TD5 Land Rover Defender build
    S4_dan's Avatar
    Jan 2006
    1,599
    Hi,
    If you could find the wire colours out for me please that would be great.
    To be honest where the car is and the gradient of the slope to push it out of would be very difficult.
    Towing would be difficult too due to the sharp left bend exiting the drive!
    DOing it via the wires would be a better option.
    Regards,
    Dan
    2002 2.5 V6 Quattro
    "Stick a V8 in it!"
    15,370
    Manual says red-black is the starter feed, and red is the main live, so if you try bridging those two, with the ignition on and see what happens.
    S4_dan's Avatar
    Jan 2006
    1,599
    Stripped the cowling off tonight and all i did was move the main connector block at the end of the igniton barrel and everything is working again now.
    Very strange though how it just seems that needed moving ever so slightly to get it working.
    Cheers guys.
    Dan
    2002 2.5 V6 Quattro
    "Stick a V8 in it!"
    15,370
    its probably signs that its on its way out mate, i'd look at changing the switch anyway
