Sky InsuranceVolks Autos
Results 1 to 22 of 22
    Jul 2008
    Birmingham
    629
    Are these B6 Aero wiper arms?
    Got them from eBay a while ago but never used them because they're not a standard fitment.
    A4 1.8TQS
    Jul 2008
    Birmingham
    629
    Part numbers are:
    4B2 955 407 C
    4B2 955 408 C
    A4 1.8TQS
    Oct 2007
    2,597
    Not B6 parts.
    B6 arms begin with 8E0.
    Jul 2008
    Birmingham
    629
    Parts are 6a on the photo and the image shows an Aero wiper... but how do they fit?! I thought there's a pin which slides through the mounting point on the blade but these look quite different...
    ...Siena?!
    A4 1.8TQS
    Jul 2008
    Birmingham
    629
    Quote Originally Posted by Siena View Post
    Not B6 parts.
    Sorry, you're right - I meant A6. They were from a 2002-ish A6 and I found them listed under that model on Vagcat.
    A4 1.8TQS
    Oct 2007
    2,597
    Hmm, seem different to mine.
    So the B7 ones have different attachment points, unless they're the same, and I can't remember.
    I bought both the arms and blades at the same time, and they were a doddle to mate together.
    Jul 2008
    Birmingham
    629
    Thanks for your help. I might just take the arms down to GSF and see what they've got. Then go on eBay and get them for half the price.
    Cheers.
    A4 1.8TQS
    Jul 2008
    Birmingham
    629
    P.S.
    What do you do if the mounting holes are a different diameter? When I put some Mk5 Golf Aero blades/arms on my Mk3 Golf I just got the trusty Dremel out and made the holes bigger.
    Probably not the best option since they're splined for a reason... but they worked nonetheless.
    A4 1.8TQS
    Oct 2007
    2,597
    The B6/7 spindles are much, much larger than B5 ones, so the arms had massive holes.
    I had metal hollow cones turned to act as adapters, so the cones slid over the smaller B5 spindles, then the B7 arms fitted a treat.
    Jan 2004
    York
    1,653
    If you want aero wipers for the B5, the easiest ones to get for fitment (as in no adaption what so ever) are Passat arms and blades
    MY15 8V S3 Sportback with options
    jcb
    Sep 2005
    uk
    4,077
    they look the same as teh 8E arms I got from germany eBay
    As sienna says, needs cones.
    they sit too far up for my liking.
    wil check the part number
    Sienna, do you want mine so you can have two passenger side ones?
    Oct 2007
    2,597
    @ Jcb: Thanks, but I've already purchased an extra passenger side one.
    Just need to find time to transfer the old arm over to the new base, to retain a lower profile.
    jcb
    Sep 2005
    uk
    4,077
    flared pin fitting isn't it. do you have to drill it out?
    Oct 2007
    2,597
    No, didn't have to drill out, as it's much larger than the B5 spindles.
    The adapters were made to "step-down" the larger items to match the much smaller shafts.
    Jul 2008
    Birmingham
    629
    Siena - they look very similar to yours. I tried the O/S arm on and the holes are a fraction too big and they have that distinctive elbow I pointed out in the other thread. Either way, I don't like them so back on the 'bay they go.
    A4 1.8TQS
    jcb
    Sep 2005
    uk
    4,077
    have some adapter cones if you want....
    Jul 2008
    Birmingham
    629
    Sorry, Siena, they look nothing like yours. :D
    I'm ill at the moment so excuse my stupidity...
    A4 1.8TQS
    Jul 2008
    Birmingham
    629
    Quote Originally Posted by jcb View Post
    Tempting... but I don't like the look so I'll wait until I find some B5.5 Passat arms. Out of interest, how much do you want for them?
    A4 1.8TQS
    jcb
    Sep 2005
    uk
    4,077
    5 and I will post them to you for free
    Jul 2008
    Birmingham
    629
    Ooooh... how do you know they will fit? Tempting... let me find a price for a pair of blades and trial fit both arms and I will get back to you.
    A4 1.8TQS
    jcb
    Sep 2005
    uk
    4,077
    I know they fit because I ran those wipers for about a year before I swapped them for passat items.
    they are also conical so will fit most shapes as you tighten the nut.
    mine are brass.....
    bling
    Jul 2008
    Birmingham
    629
    What are the part numbers of the Passat wiper arms? There are two listed on VAGCAT:
    Left: 3B2955409B and ...C
    Right: 3B2955410B and ...C
    Any ideas?
    A4 1.8TQS
