Sky InsuranceAH Fabrications
Results 1 to 8 of 8
    jcb
    Sep 2005
    uk
    4,077
    where does the rear washer line run on an avant?
    inside or outside for the length of the car?
    pump is at the front, I have a wet rear passenger footwell and no spray at the back.
    if it runs inside anyone know where?
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    Bridgend, South Wales
    617
    Quote Originally Posted by jcb View Post
    Its definitely on the inside of the car as when I bought my A4 Avant a few years ago one of the first things I noticed was the fact that no washer fluid was reaching the rear wiper....
    Traced it to the washer pipe that had popped apart at a union in the front passenger footwell up near the glovebox (buried under the carpet), fixed that and has been fine ever since.
    At the same time I also discovered the now-common phenomenon of the pipe carrying fluid through the rear wiper motor corroding and causing water leaks into the rear tailgate and the washer motor mechanism itself, put a replacement motor in and that has been fine ever since too......
    '99 Ming Blue A4 Avant TDi SE 110 + Dragon Performance Tuning Box
    Factory sunroof / Cruise / Aircon + Climate / Royale Blue leather
    '72 1302LS Karmann Beetle Cabrio Silbermetallic
    '63 Karmann Ghia Sunroof Coupe Pacific Blue
    Aug 2008
    148
    had a problem with mine no water from back traced line to drivers side, pipe runs in the roof on mine connection had come apart and was filling the boot. but mine (99my) runs from the tailgate onto the drivers side then along the drivers side following the wiring. if you pull the side trims from the boot you should see which side it runs or just pull up the back seat
    dieselfitter251's Avatar
    Blow ma own trumpet?
    Jun 2007
    High 'C's
    1,130
    On the Avant, how the heck do you get into the bridging wire from the tailgate to the body?... I think I've got a bvreak here, pain in the arse. Any hints?
    Ford Mondeo 2.0i Durtec Ghia X Estate
    Leather / Dog Hair.
    Dieselfitter 251
    A4 avant '97 1.9tdi q
    a.k.a. STINKY
    [B]250k!
    ..she's gooooonnnne!!!!
    Aug 2008
    148
    if you mean the wires that run from the body to the tailgate through the rubber boot its just a case of pulling off the boot and peeling it back to get to broken wires. fiddly repair at best of times. ideal way is disconnect loom from tailgate pull back into car extend wires so new wires are now in the boot and replace loom good luck
    Jun 2007
    High 'C's
    1,130
    uuuurghhh..Cheers, Hadn't thought of that approach.
    p.s. JCB... sorry for high jacking your post!
    Leather / Dog Hair.
    Dieselfitter 251
    a.k.a. STINKY
    [B]250k!
    jcb
    Sep 2005
    uk
    4,077
    bloody outlaw!
    Jan 2009
    Up tiddly up up
    71
    Its worth looking above the drivers side rear wheel arch, there is a union there which comes apart, usually when the rear jet has frozen. I have wrapped mine in insulating tape and hasnt been a problem since.
    Watch the front one in the footwell, when this leaks it runs straight into a multi connector block and if not cleaned will cause failure of rear lights. WD will sort this out.
