Chris NottJMB Retrofits
Results 1 to 19 of 19
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,390
    Seat Change Avant into a Saloon
    I know I have seen some notes on this before but cannot find them now. (On a poor mobile connection)
    I have a leather interior from an avant I am going ti fit into my saloon, can anyone give me some tips for installing the top part of the rear bench?
    everything else is dead straightforward I know
    2001 S3 (AMK)
    AEM WMI Kit, Black Silicone Hoses, Badger5 TIP with Cone Filter, AH Fabrications FMIC, Relentless Manifold Downpipe & Sport Cat, Miltek Cat Back Exhaust, VAG Aero Wipers, Forge FMDV008 Re-Circ, Revo Stage 2 Remap with SPS+ Tweaks, 2.0 TFSI Coil Pack Mod, B&M Short Shift, RNS-D Retrofit, Brembo & B5 2 Piece Rotor Conversion
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    I got 2 bendy pieces of metal (1 for each side) made up from A.N.Other local engineering/metalwork firm to fit some avant fixing bolts to. Never made up any specs other than a folded up cereal box with biro measurements made on it, but it's been solid as anything.
    Pretty straight forward when you see what you need to remove and what the avant needs. Just bolted mine to the same place as the Saloon fixtures.
    Mo power, mo problems
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,390
    how did you get your rear seat out? I think I need to remove the headrest guides as these secure the top of the back cushion but they seem solid, any handy tips/techiniques
    do I need to cut some of the metal work out from behind the seat back then?
    cheers
    2001 S3 (AMK)
    Feb 2007
    Liverpool
    1,693
    My previous seats already had the 60/40 split, so it was really easy. Thinik it may be more compicated if you've got the fixed rear seats.
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    is your saloon a quattro? if not theres a bit more to it as you wont have any mounting brackets or holes to mount them
    Feb 2007
    Liverpool
    1,693
    Quote Originally Posted by olds_kool View Post
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,390
    no mate just 2wd
    what else will be needed?
    2001 S3 (AMK)
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    Quote Originally Posted by Blue_Thunder View Post
    non quattro saloons all have fixed back seats, quattro and avants have split folding
    leigh i remember byzan posting up how he did it if you can find it
    but you need the centre mounting bracket and two end pins and a way of fixing them to the shell, then original fixed back needs removing and upper latch mounts would need fabricating, thats if you want the seats to fold, might be easier to just permantly fix them in place somehow
    Fraser's Avatar
    Aug 2003
    the north
    586
    my t sport non quattro and has split folding seats
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,390
    mine are currently solid back, I am not at all bothered about them folding so just need to work out how to get the current back off and am going to see how I can mount them
    any tips to get the current one off?
    2001 S3 (AMK)
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    easy, remove the bottom squab, then look just below the backrest and you will see 2 little torx headed screws, undo them and the rear will slide up off its 3 mounting lugs ta da !!
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,390
    Quote Originally Posted by Byzan A4 View Post
    Thanks mate
    I thought I had to remove the headrest guides some how first
    2001 S3 (AMK)
    98 A4 1.8SE
    May 2008
    Derbyshire
    135
    Quote Originally Posted by Fraser View Post
    yeah, my '98 1.8 SE has split folding seats, too. maybe it's something they brought in on facelift cars?
    Fraser's Avatar
    Aug 2003
    the north
    586
    Quote Originally Posted by brendan View Post
    mine is 96 t sport so pre-facelift
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    i stand corrected, very rare though mustve been an expensive option on fwd saloons and standard on quattros
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,390
    UPDATE:
    to remove the back seats I had to gently pry out the guides from the rear head rests and remove the screws on the bottom mounting brackets then the seat pad pulls forward and off.
    The bottom seat pad from the avant clips in in normal way.
    the back pads are going to be screwed into place through the rear firewall and the side bolsters are clippid in place on the bottom and have tie wrapped the top mount of the bolster to the fire wall and secures perfectly witout being able to see the tie wrap
    2001 S3 (AMK)
    jcb
    Sep 2005
    uk
    4,077
    sport and Se models are higher spec hence the split.
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,390
    mine is a sport model mate, no split!?
    2001 S3 (AMK)
    Apr 2004
    12,523
    My 98.5 se didnt have split seats as std, it has now tho,lol
    Sorry Leigh, i forgot all about the headrest guides, well spotted
