Chris NottSky Insurance
Results 1 to 27 of 27
Thread: FAO 2.7T owners
    Mar 2008
    Ipswichish
    127
    FAO 2.7T owners
    As seems to be common place with most dual mass flywheel equiped cars, mines foobared, so I've been looking into single mass replacements.
    I've spoken to one of my customers from work who specialise in motorsport spec and custom flywheels, they do a fair bit of work for various teams in btcc, formula ford etc etc.
    They've said to me that they can make up a billit steel flywheel, either lightened or std weight with the timing holes for the 2.7 no problems, infact Siena has one of their flywheels for his V8 conversion.
    After a bit of negotiation they've said that if I can come up with around 5 orders for these, they can sell them to me at a reduced rate, as with any machine work it takes more time to set up the machines than it does make the product, so making say 5 is far more cost effective than just 1.
    So who here would be interested if I could get one delivered to your door for 265?
    which is about 100 less than their RRP!
    '99 noggy blue S4 / '84 mk1 Astra GTE turbo
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    ive got the light weight one , its really good , dont know if its me its just a bit rattely at very low revs under strain has been from the very start
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    Mar 2008
    Ipswichish
    127
    which clutch are you using?
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    rs4
    Mar 2008
    Ipswichish
    127
    was the route I was planning to go, can get an LUK one for about 150, dunno if that's a good price or not tho.
    Oct 2007
    2,597
    Tufty, believe me, you don't want to be use a LUK clutch, I wouldn't run one on a mildly modified 1,8T, never mind one with the spec you're planning!
    I'm running an RS4 clutch too.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,390
    What brands would you recommend Siena?
    Valeo? Borg&Beck?
    TD5 Land Rover Defender build
    Oct 2007
    2,597
    I'd only recommend Sachs.
    Or of course, RS4 clutch.
    "Stick a V8 in it!"
    15,390
    ie an OE RS4 item?
    Who makes the OE RS4 item?
    "Stick a V8 in it!"
    15,390
    ie an OE RS4 item?
    Who makes the OE RS4 items?
    Oct 2007
    2,597
    Yes, OEM RS4 clutch.
    Made by Sachs.
    Mar 2008
    Ipswichish
    127
    Now you say that, my sachs clutch in the astra is only rated for 150bhp and is quite happy holding almost twice that, even at the pod.
    ALPINE's Avatar
    Yes its diesel, now cry u lost
    Apr 2008
    S/E LONDON / KENT
    3,086
    I use a luk clutch on my car, as does my mate ash on is mk4 golf thats over 300bhp
    i payed 98 plus vat as did my mate about 14 months ago!
    hope this helps
    Now to many mods to list! Lots of power, torque and Leather!
    Mark_B's Avatar
    Jan 2007
    Surrey/Hants Border
    19
    Quote Originally Posted by Tuffty View Post
    What are the symptoms please?
    Mar 2008
    Ipswichish
    127
    Quote Originally Posted by Mark_B View Post
    Will usually start off feeling like a duff engine mount, you'll have a "clunk" feeling when lifting the clutch on gearchanges.
    they can also rattle on idle and in bad cases knock and clunk when on and off the throttle.
    I've also found on some that when you turn the engine off, theirs a clunk / rattle as the engine stops.
    dsmclark40v's Avatar
    Sep 2006
    Hampshire
    715
    Would a flywheel for the 2.7t fit a 2.8q? they are pretty much the same engine aren't they? if so I might be interested
    Sam
    Mar 2008
    Ipswichish
    127
    Quote Originally Posted by dsmclark30v View Post
    Sam
    I've been trying to find the answer to this, but have come up blank so far.
    as far as I can see, they both run the same size clutch plate, and i would have thought that the crank mounting would be the same, so it's just down to wether the pulse cutouts are the same i guess.
    Oct 2007
    2,597
    N/A 30V flywheel has different profile to S4 / RS4 item.
    "Stick a V8 in it!"
    15,390
    Profile as in crank trigger, or as in the thickness of the friction surface?
    Ie if you used a S4 flywheel and clutch together would it work on a 2.8 30v?
    Oct 2007
    2,597
    Trigger's in the same place.
    6-speed cars have a different flywheel profile, as the bell housing depths are different to a 5-speeder.
    "Stick a V8 in it!"
    15,390
    but you can fit a 6sp tranny to a 5sp car with no flywheel issues?
    Oct 2007
    2,597
    I've done the above in the past, but had severe clutch slippage - the pedal didn't feel right either, as the release bearing was further away from the pressure plate.
    It's the very reason the S4 / RS4 run a 11,2mm spacer between the engine and tranny, and the regular 12V / 30V models don't.
    "Stick a V8 in it!"
    15,390
    so if you were doing a 6 speed swap should you be installing that spacer too? Bit confusing, i thaught all these parts were a straight swap, but i did wonder about the spacer used on the S4 having an effect on the input shaft and the release bearing...
    Whats your plan for the V8? will it bolt straight up to the 6sp as you have a custom flywheel? or will you require some kinda spacer?
    Oct 2007
    2,597
    No spacer required for mine.
    My flywheel is the same dimension as an OEM S8 6 speed manual item.
    6 speed bolts straight up.
    "Stick a V8 in it!"
    15,390
    cool stuff, as i said previously, i'll be after one of those flywheels for the landrover (and maybe another if i get this V8 trackcar sorted), but atm spare money is non existent, and i really need to find a workshop to work on the motor, otherwise the flywheel will just end up sat in the porch for months :P
    Oct 2007
    2,597
    Cool, let me know when you're ready, I have the dimensions still.
  28. #27
    Mar 2008
    Ipswichish
    127
    bump
