S4 Vagcom output
aragorn
"Stick a V8 in it!"
Staff member
Glenrothes, Fife, Scotland
Ok i've had this posted up on RS246 but hopefully posting here will get a bit more coverage.
Been doing some vagcom logging runs on craigs S4 and noticed it seems to be cutting throttle once it gets up the revs.
Thats the last log we did (full throttle 3rd gear), which shows throttle angle as well as boost pressure, well at least its supposed to show boost pressure...
As you can see the throttle closes down once the RPM's reach about 4800, the feeling from googling seems to be that throttle cut like that is caused by overboosting, so we want to look into that next, however with the logs not showing boost properly it leaves us a bit blind.
I'm going to try it again, theres another few channels i can log, which are supposed to show boost pressure (117 and 118) so i'm going to try those first to see if it gives me any more sensible readings...
Any ideas on what would be causing the overboost on a stock car? i'm thinking along the lines of a faulty N75 valve or a split vacuum pipe somewhere...
Original post is here: http://www.rs246.com/index.php?name=PNphpBB2&file=viewtopic&t=73850
Faulty N75 would be one potential cause. Could also be a boost leak.
A knackered wastegate could also cause overboosting but is fairly uncommon AFAIK.
First things to check:
Any DTC's stored?
Pressure test
Block 032 on Vagcom to check fuel trims
Another thing is the DV's - if they are sticking and not opening fully, this would also cause overboosting, but you wouln't expect to see this at WOT, only on lift off.
only DTC he's getting is "Power Supply Terminal 15 Voltage Low" and it only appears on startup i think.
If you clear it with the motor running it stays cleared and doesn't return...
The fuel trim i posted up over on rs246, -0.8% on one value and 0% on the other.
I'm thinking along the lines of either N75 itself, or the pipe work to/from it...
DV's are on the list of parts that he wants to replace anyway as a matter of course, and he wants to remove the F-Hose and do an N249 delete too.
Not pressure tested it yet, as he hasn't bought the kit to do it, used to be someone selling them on ebay but they've vanished. Might have to knock something together myself to do it.
Re the fhose/249 delete, we need to buy some pipe to do it, do you know what size it needs to be?
938
895
20
2K
964
