Page 2 of 2 FirstFirst 12
Results 41 to 59 of 59
Thread: headlights
  1. #41
    Oct 2007
    2,597
    Quote Originally Posted by diesel-a4 View Post
    Hey Siena, further to our PM's (business mode)
    how much for the 1 piece S4 lights with HID installed ready to rockaroll
    To be honest, it's best to buy OEM 1-piece headlamps (if you haven't already got them) then install a decent aftermarket HID system.
    Just the OEM HID ballast and bulbs work out 573.44 and 243.18 respectively.
    From us, 540.50 and 198.02 respectively.
    Add that all up, + 251.45 for a pair of OEM Valeo 1-piece (199.75 from us) you're looking at the cost of a '98 B5 quattro.
  3. #42
    audinary's Avatar
    Aug 2008
    Frinton-On-Sea
    646
    B5 quattro for less than a grand? ****! I've been had! :P
    '98 Santorin Blue 1.8t Sport
  4. #43
    Oct 2007
    2,597
    Well, my B5 quattro cost me 500.
  5. #44
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,317
    Yer take a look on ebay, early 2.6 quattros are going on there for under a grand all the time. I've seen a few sell for 5-600 with nothing wrong with them!
    TD5 Land Rover Defender build
  6. #45
    ALPINE's Avatar
    Yes its diesel, now cry u lost
    Apr 2008
    S/E LONDON / KENT
    3,086
    Quote Originally Posted by Siena View Post
    yes but it was a dog and looked nothing like it does now!
    Now to many mods to list! Lots of power, torque and Leather!
  7. #46
    dieselfitter251's Avatar
    Blow ma own trumpet?
    Jun 2007
    High 'C's
    1,130
    My B5 quattro has cost me the price of a B6 quattro!!!
    Would still rather have a B5 though :O)
    Ford Mondeo 2.0i Durtec Ghia X Estate
    Leather / Dog Hair.
    Dieselfitter 251
    A4 avant '97 1.9tdi q
    a.k.a. STINKY
    [B]250k!
    ..she's gooooonnnne!!!!
  8. #47
    Oct 2007
    2,597
    Wasn't in bad shape, Alpine.
    Just an average B5, with her own share of scratches and stuff.
  9. #48
    PhilR's Avatar
    One Ate Tea
    Jan 2006
    UK
    330
    Hi Siena what do you use to convert from the round to the d shaped plug ?
    I cant find a scrap facelift car, can i buy the d shaped plug (car side) from the dealer and use it to make a new harness ?
    At the moment i am running the original (round plug) harness where i removed the headlamp side plug and harness and fed the extended harness through the hole but i am about to convert to HID and want to sort this tempory fix
    Jun 2007
    High 'C's
    1,130
    Quote Originally Posted by PhilR View Post
    Hey PhilR,
    I got all the relevant bits from Audi, I'm sure Siena can sort you out.
    2 x 8pin D plugs 8xpre-finished connectors, (the wires are double ended, chop them in half , 8 of will give 16 wires, enough for both sides.) The Indicators should be able to run off the the existing connectors. You'll have to cut and splice the original round connectors, it's quite basic electric tbh/imo. You'll be fine.
    Here's a handy tech article from audiworld:
    http://www.audiworld.com/tech/ext17.shtml
    I used my existing round rubber terminal/plug covers to seal them from any water.
    Biggest leap of faith getting that 'ole angle grinder out if you decide to go for the e-codes on a pre-99 car.
    Leather / Dog Hair.
    Dieselfitter 251
    a.k.a. STINKY
    [B]250k!
  11. #50
    PhilR's Avatar
    One Ate Tea
    Jan 2006
    UK
    330
    Cheers, already got the headlights fitted and working,
    well please with the new look
    just with a temporary harness still running the round plug, just want to finish it off properly now ready for HIDs
    Do you know what the part numbers for the plug and connectors are ? roughly how much did it cost ?
  12. #51
    Jun 2007
    High 'C's
    1,130
    Off the top of my head no. Plugs and wires came to 25, maybe even less, not a lot of cash.....
    8D0973734 D-plug The illustration http://www.vagcat.com/epc/cat/au/A4Q...24/57/2827050/
    shows the round connector but this was the same when I went to Audi. Just tell them it's for a 2000model or give them the part number of the headlamps so they can do a related search. They're about 3 quid or something. I can't find any info on the wires, but thats where to get them from.
    p.s. car looks great!
    Leather / Dog Hair.
    Dieselfitter 251
    a.k.a. STINKY
    [B]250k!
  13. #52
    PhilR's Avatar
    One Ate Tea
    Jan 2006
    UK
    330
    cheers for the info ! and thanks
    is this the wire?
    found 2 versions though 1mm and 2.5mm
  14. #53
    Izzy1's Avatar
    Vorsprung Durch Technik
    Sep 2008
    Birmingham, UK
    348
    well i'd check the voltage to the back of the bulbs to begin with, the voltage on the bulb terminals themselves should be within .2v of the battery voltage with the engine running and the lights on. ie check the battery first, you should get around 13.9-14.2v, so say you get 14.1v at the battery the light connectors shouldnt have much less than 13.9v.
    Checked the Voltage output last night and the Battery was showing 13.9v and the back of the bulbs was 12.4v i see i'm loosing a bit of voltage but should that make a big difference on the light output?
    would the best bet be to buy new bulbs?
    i've seen some HID kits on the net for around 35. are these worth getting or should i save a bit more and just but from hids4u?
    Izzy
    Bora TDI sport
    Audi A4 TDI
  15. #54
    "Stick a V8 in it!"
    15,317
    Hmm that is quite a lot of voltage drop.
    I've never checked mine to see how good the wiring is, but i'd expect that to be much higher as it basically means all of that voltage difference is being dissipated as heat somewhere in the wiring loom...
    Try this:
    Engine running and lights on...
    Measure the voltage across the battery (again, just for reference)
    Measure the voltage between the Battery -ve and the bulb +ve
    Measure the voltage between the battery +ve and the bulb -ve
    This will hopefully show whether the voltage drop is happening in the feed to the bulbs, or the earthing from the bulbs back to the car.
    I'm not sure on the difference between the cheap HID's and the hids4u kits, i suspect the cheap ones might take longer to fire up, but might otherwise be ok.
    Buying new bulbs would probably help a bit, however you need to try and fix that voltage drop first!
    I will try and take the same measurements on our car tonight, as long as its not pissing down, and see if that much drop is normal.
  16. #55
    Jun 2007
    High 'C's
    1,130
    is this the wire?
    Yup, that's the ones, but I didn't know there were different weights. I think 2.5mm sounds right.
    Leather / Dog Hair.
    Dieselfitter 251
    a.k.a. STINKY
    [B]250k!
  17. #56
    Izzy1's Avatar
    Sep 2008
    Birmingham, UK
    348
    Try this:
    i tried the voltage test with the ignition on but engine was not running. would that make a difference?
    i will try again tonight and let you know of my findings.
    Izzy
    Bora TDI sport
    Audi A4 TDI
  18. #57
    "Stick a V8 in it!"
    15,317
    oh right! 12.4v is pretty much what the battery would be outputting with the engine off... not sure how you managed to get 13.9 over the battery with the engine off though?
    Unless you checked the battery with the motor running then shut it off when testing the lights?
  19. #58
    Izzy1's Avatar
    Sep 2008
    Birmingham, UK
    348
    nope i got 13.9v with the engine off.
    will try again both with engine on and engine off and record my findings and let you know.
    Izzy
    Bora TDI sport
    Audi A4 TDI
  20. #59
    "Stick a V8 in it!"
    15,317
    i presume there was just some charge built up from the alternator or something if the engine had been running shortly before you tested it...
    a healthy battery with no load will output around 12.8v, a flat one nearer to 12.4-5v
    12.4v at the lights with the engine off and a healthy battery sounds acceptable enough to me.
