AH FabricationsVolks Autos
Page 1 of 2 12 LastLast
Results 1 to 40 of 51
    ALPINE's Avatar
    Yes its diesel, now cry u lost
    Apr 2008
    S/E LONDON / KENT
    3,086
    AUDIS ARE SO GAY!
    why the fook does my turbo look like this...
    have not driven it hard... its under boosting, its slow, (almost feels like a n/a) its hesitats badly.
    im starting to loose interest in audis very quickly.
    WHY??
    Now to many mods to list! Lots of power, torque and Leather!
    Adam-D's Avatar
    Dec 2007
    wirral, merseyside
    458
    could be setup wrong, possibly ignition timing? not enough fueling?
    or a blocked cat/exhaust
    stuff for sale.
    black door cards 50
    black textured "carbon" trim 30
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    cat is a possibility, would go some way to explain the no boost and lack of performance.
    Have you ever had the car missfiring? the unburnt fuel from the missfires ends up burning off inside the cat, and melts its insides.
    My dads A4 had a blocked cat at one point and it was VERY slow (think 1.6) but also if you tried to accellerate it just bogged down, you had to very gently feather the throttle to get it moving.
    I've got a gutted cat laying here you can have cheap if you want...
    Does vagcom tell you anything?
    TD5 Land Rover Defender build
    jcb
    Sep 2005
    uk
    4,077
    running lean, or not flowing through the CAT,
    if it was running rich and unburnt fuel was going through that actuallt cools down the exhaust system from combustion chamber backwards.
    get it on VAG com and log the lambda sensor(s), timing and fuelling
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    there has been no miss firein.
    just all of a sudden juddered yesterday after filling up with fuel and its not been right since.
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    ill get on the vag com later oncwe im back from work
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,082
    Ah mate you really aint having much luck
    I would say there is something not quite right with the fueling or ignition as it seems your EGT's are way higher than they should be.
    Is possible you had a bad tank of fuel. I put 20 in at my local Sainsburys and shortly afterwards my car started to pink, cough and missfire. I limped it about and then filled it to the brim with Shells finest Optimax. Within a few miles things were settling down and by time it came to fill up again the symptoms had gone completely
    Life begins at 140mph
    www.passionford.com
    Lee Goodall's Avatar
    ..got my head together!
    Oct 2007
    UK - Midlands
    2,223
    Quote Originally Posted by ALPINE View Post
    I deleted it!!
    WHY??
    Haven't you had issues with a glowing turbo before?? On your old engine? or am I confusing myself?
    "Stick a V8 in it!"
    15,370
    ye your right!
    I'm thinking the cats to blame tbh. as i presume you kept that from the old engine, and the same symptom on both leaves one common part...
    Oct 2007
    UK - Midlands
    2,223
    ye your right!
    Yep that's where I was going..
    Although I think Alpine might be running the injectors off of his old motor too??
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    yep same cat.. same injectors. ill go and Vag com it in a bit and let you know.
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    just V com`ed it and theres nothing.
    i done a log but its all just numbers. dont think it will make sence to any 1.
    Oct 2007
    UK - Midlands
    2,223
    Can you check fuel trim?
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    how do i do that?
    "Stick a V8 in it!"
    15,370
    a bit pikey, but you could try unbolting the cat from the turbo and seeing if you get any more power, or if it runs any better?
    Fuel trim is just a vagcom reading, not sure where it is, but gives you an idea if the ECU is trying to compensate for something.
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    that will wake the neighbourhood up!! lol i could try it tho. just looked on ebay for a de-cat pipe! 102!! HAVE A LAUGH!
    any 1 got 1 they wanna sell? or swap for somthing even? i have most AEb parts up for grabs. Car is skintin us right out Who owns who?
    Oct 2007
    UK - Midlands
    2,223
    Think it's block 032 with VAG.COM but I'm not certain.. anyone??
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    will this ever stop?? is every 1s Audi thing after thing, week after week? im gonna have a near brand new car soon at this rate!
    "Stick a V8 in it!"
    15,370
    i did say at the start of this post i have a gutted cat that can be purchased for a small fee
    Was on my 1.8T until just before the MOT when i swapped it out for a real cat, thinking it had simply packed up. Only once i got it off did i realise it had been gutted by some previous owner!
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    what price is a small price?? if its gutted could i not just do this to mine?
    "Stick a V8 in it!"
    15,370
    Tenner plus post or something.
    You could do it to your own though. Just take it off, beat the insides out with a big stick and put it back on.
    You'll probably need the two gaskets too.
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    could give it a go mate i suppose. cant do nothing till end of month tho. we skint as f00k!
    Cheers aragon
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    I have gaskets i could add to your package mate. atry slackening the bolts so it blows a bit. If the power is back, its the cat, if its the same but noisier its the fueling
    Jul 2007
    Essex
    400
    Gut the CAT if you MOT isnt due for ages then its deffo worth a go. Personally id say its a blocked cat so deal with it in the best way.
    Ming Blue A4 B5 RS4 Replica (SOLD)
    T28 Kit (SOLD)
    Oct 2007
    UK - Midlands
    2,223
    Poke your cat with a big stick?? What would Rolph Harris say about that?
    FactionOne's Avatar
    Administrator
    May 2004
    Preston
    3,059
    The truth they're trying to keep from you is that IPv6 has nothing to do with address space; we're actually running out of full stops.
  28. #27
    Oct 2007
    UK - Midlands
    2,223
    I've found a bit of kit that should be purrrrfect for the job..
  29. #28
    Oct 2007
    2,597
    Now feline creatures, I hate with a passion.
  30. #29
    Oct 2007
    UK - Midlands
    2,223
    Quote Originally Posted by Siena View Post
    Suppose you like the sound of the pokey-cat stick then?
  31. #30
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    for a change siena, i would have to 100% agree with you there! there the cutest wheel chocks ever created!
  32. #31
    "Stick a V8 in it!"
    15,370
    You tried unbolting that flange yet?
  33. #32
    Oct 2007
    UK - Midlands
    2,223
    Unbolting the flange??.. you've opened up a whole world of metaphors now ha.
  34. #33
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    lol! i gotta go to work shortly so cant really get messy till i finished. been busy doing other stuff this morn to look. got tomorrow off so that will be the day!
  35. #34
    Oct 2007
    2,597
    I did roll over a ginger tomcat a couple of moths ago.
    I got into my car, and let the handbrake off before I started the engine, for some reason.
    I heard this unearthly shriek, got out of the car, and behind the passenger rear wheel was this tomcat.
    The car had rolled over him, missed his head; his entrails were bursting out of his backside, eyes, ears, nostrils etc.
    He had become a flat-packed cat.
  36. #35
    "Stick a V8 in it!"
    15,370
    Quote Originally Posted by Lee Goodall View Post
    Oh yea
  37. #36
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    lmfao.. that actually made me spit my drink out with laughter!!
  38. #37
    Oct 2007
    UK - Midlands
    2,223
    I know.. you didn't start the engine because he would've got away
  39. #38
    Oct 2007
    2,597
    Now come on, Lee.
    Why would I do such a thing?
  40. #39
    audinary's Avatar
    Aug 2008
    Frinton-On-Sea
    646
    If Cats were born metallic blue, we wouldn't have to spray paint them
    '98 Santorin Blue 1.8t Sport
  41. #40
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    Block 32 is the one to measure fuel trims.
    Mo power, mo problems
