DNA TuningAWEsome GTI
Results 1 to 35 of 35
    Nov 2008
    19
    Post Thanks / Like
    ABS problem - what do to next ?
    Hi,
    Hoping someone could suggest where to go next with my A4 ABS problem.
    A few weeks ago I got the orange abs lights and the flashing brake fault light up (complete with 3 beeps when starting the car).
    My handheld code reader indicated an ECU fault.
    Had my unit tested and it was 'unrepairable' so replaced it with a used unit. This cleared the red warning light/beep.
    The orange ABS light would come on after a few minutes driving - before it did the ABS seemed to operate when the brakes were applied even a low speeds.
    I re-scanned and got a rear ABS sensor fault.
    I removed and cleaned the sensor (it was covered in metal particles - like a magnet and iron filings).
    This cleared all the fault code and the orange light but the ABS seems to operate everytime the brakes are applied even at low speeds.
    I'm a bit stuck where to go from here and would appreciate any help
    Thanks a lot
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,401
    Post Thanks / Like
    So you've investigated the wheel sensor and the symptoms have changed. I would replace that particular sensor.
    Are you still getting a fault related to the rear sensor?
    "Stick a V8 in it!"
    Cleveleys, Lancashire
    11,840
    Post Thanks / Like
    Yer the fact the ABS is activating means that the AbS ecu thinks one of the wheels is locked, ie no signal from the sensor. Have you driven the car properly? you usually have to get upto 15-20mph before the ABS ecu will realise there is a fault so if youve just driven it round the street for testing then its likely the fault it still there.
    I'd replace that rear sensor.
    For Sale: Breaking B5 A4 - Check my eBay page!
    Wanted: Facelift A4 Front Bumper with Headlight Washers.
    2000 A4 1.8T Sport Quattro Avant, Beere Pearl, TT Carriers and B6 312mm Disks.
    2000 A4 1.8T Sport Quattro Saloon, Black-ish, Now Running!
    1997 S4 - PPC £999 Challenge Track Car Build starting soon!
    Audi V8 powered Land Rover Defender build in progress.
    dieselfitter251's Avatar
    Blow ma own trumpet?
    Jun 2007
    High 'C's
    1,130
    Post Thanks / Like
    Agreed, though if you can, you may want blast the hub with air to get any sebris of the ABS ring, might as well do all four, give it all a good clean up.
    You may still have to replace that sensor.
    Ford Mondeo 2.0i Durtec Ghia X Estate
    Leather / Dog Hair.
    Dieselfitter 251
    A4 avant '97 1.9tdi q
    a.k.a. STINKY
    [B]250k!
    ..she's gooooonnnne!!!!
    Nov 2008
    19
    Post Thanks / Like
    Thanks for the suggestions.
    After a good drive I'm now getting the orange ABS light back up.
    I've ordered a new sensor and will give things a good clean when I fit it.
    Thanks again
    Nov 2008
    19
    Post Thanks / Like
    Just fitted the new sensor.
    No ABS light on dash and no codes appear on my hand held reader.
    But....ABS still coming on at low speeds.
    Help - where do I go next ?
    Thanks in anticipation
    Apr 2004
    Swansea, South Wales
    528
    Post Thanks / Like
    Dude, broadly similar problem to my car. Did you use vagcom to tell which sensor was toast? If so, how?
    1999 S4, MIJ Performance exhaust with 100 cell cats
    Nov 2008
    19
    Post Thanks / Like
    Havent got VAG-COM (yet)
    Been using a hand held OBD code reader. It told me the rear right was gone.
    Jun 2007
    High 'C's
    1,130
    Post Thanks / Like
    What car you got? If it's a quattro then there's a hefty price for replacement rear sensors, if it FWD then give Aragorn a bell ...
    Leather / Dog Hair.
    Dieselfitter 251
    a.k.a. STINKY
    [B]250k!
    "Stick a V8 in it!"
    11,840
    Post Thanks / Like
    me? i dont have any FWD bits...
    i think you may be thinking of auoran whos breaking a V6?
    naefeart_A4's Avatar
    Bonkers
    Sep 2006
    Aberdeen, Scotland
    156
    Post Thanks / Like
    I've just had this problem rectified on my tqs - Audi replaced both rear outer cv joints.
    n
    A4 1.8T Quattro Sport | H&R Springs | Milltek Cat-back | Custom Code Stage 1 | 18" BBS RXs | Falken 452s |
    Jan 2004
    York
    1,639
    Post Thanks / Like
    Yup it's me.... I've got all four sensors, front/rear hubs, ecu, pump etc etc (abs was fine on the motor before I started breaking).... infact the whole car was fine but is worth more in bits.
    Going ..... '56 Audi A4 2.0 TFSI Sline SE quattro Avant
    To be replaced by a
    11 plate SEAT Exeo CR ST Sport Tech
    Nov 2008
    19
    Post Thanks / Like
    Replaced both rear sensors now - still getting ABS on at low speeds.
    Would welcome any suggestions
    "Stick a V8 in it!"
    11,840
    Post Thanks / Like
    whats the ABS rings like on the disks themselves?
    If they're muntered you might need some new ones, although if they've been on there that long that they're knackered, the disks probably arent in very good nick either...
    Nov 2008
    19
    Post Thanks / Like
    I'll have a look at the disks. They are fairly new - few months old - but worth a look.
    I'm rapidly approaching the limits of my knowledege - is it obvious what to check ? Is is easily accesable.
    Thanks again
    "Stick a V8 in it!"
    11,840
    Post Thanks / Like
    On a FWD the trigger ring is pressed onto the back of the disk.
    Who replaced the disks? they may have used new ABS rings, or they may have just removed the old rings from the old disks and fitted them to the new ones...
    To access them, you need to remove the brake calipers and undo the hub bearings, then remove the disk from the car.
    Jan 2004
    York
    1,639
    Post Thanks / Like
    Eh ? I thought the ring was in the hub not the disks
    To be replaced by a
    "Stick a V8 in it!"
    11,840
    Post Thanks / Like
    the hub and disk are one and the same on a FWD B5 A4.
    Disk has taper bearings inside it and the ABS ring pressed onto the back of it.
    Jun 2007
    High 'C's
    1,130
    Post Thanks / Like
    I've got two ABS rings (bought in error a while ago) for the rear if required. Nae use tae me as a've goat a qwattro....
    (sorry for the phoenetic scottish, dinnay ken whit came ower mi)...
    Leather / Dog Hair.
    Dieselfitter 251
    a.k.a. STINKY
    [B]250k!
    "Stick a V8 in it!"
    11,840
    Post Thanks / Like
    Wi dinnae aw spek like that yi ken. :P
    Jun 2007
    High 'C's
    1,130
    Post Thanks / Like
    Aye, I know. Not even my accent. I'm from Ayrshire!
    Leather / Dog Hair.
    Dieselfitter 251
    a.k.a. STINKY
    [B]250k!
    Nov 2008
    19
    Post Thanks / Like
    I'll have a look at the rings.
    Update on problem:
    Drove to work this morning - ABS came on at low speed as before. After a few miles it stopped coming on and no warning light i.e. all seemed OK. However, I then noticed a rapid ticking from the general direction of the ABS pump/controller. Does this give any more clues ?
    Jun 2007
    High 'C's
    1,130
    Post Thanks / Like
    Lost on me. Sorry. Conjecture would be that there's a problem with one or some of the solenoids in the pump / module. But that is just a guess.
    Leather / Dog Hair.
    Dieselfitter 251
    a.k.a. STINKY
    [B]250k!
    Nov 2008
    19
    Post Thanks / Like
    update
    After living with this for months I've had enough and need to resurect the fault finding.
    Sensor rings have checked out OK.
    Worth changing the pump module itself ? Is this a big job ?
    Any other testing I can do before swapping the pump ?
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    Post Thanks / Like
    what about sending the module away to one of the places that repair them and getting it checked out?
    "Stick a V8 in it!"
    11,840
    Post Thanks / Like
    is it just triggering the ABS, or is it bringing up the large warning light etc?
    If its bringing up the large warning what faults are the ABS unit recording?
  28. #27
    "Stick a V8 in it!"
    11,840
    Post Thanks / Like
  29. #28
    "Stick a V8 in it!"
    11,840
    Post Thanks / Like
  30. #29
    Jun 2007
    High 'C's
    1,130
    Post Thanks / Like
    DO you know anybody with vagcom or have access to yourself? A good indipendant garage might help, save money over a steelership too. It may give more clues than the hand held unit...hand held unit.... ffffnar!
    sorry, couldn't resist.
    Leather / Dog Hair.
    Dieselfitter 251
    a.k.a. STINKY
    [B]250k!
  31. #30
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,598
    Post Thanks / Like
    If you know someone local with a similar aged B5, you could swap your ABS ECU's to see if that solves the problem. Would be a 10 minute job.
    Mo power, mo problems
  32. #31
    Jun 2007
    High 'C's
    1,130
    Post Thanks / Like
    Good point. Where are you campervan. Most folks on here will be willing to muck in if you're close enough, all they may require is a luke warm bacon butty and a luke warm ale..... Anywhere near East Lothian ;O) ??
    Leather / Dog Hair.
    Dieselfitter 251
    a.k.a. STINKY
    [B]250k!
  33. #32
    Nov 2008
    19
    Post Thanks / Like
    Thanks again for the help.
    I've goy myself VAG com and it is showing intermitant faults on the two rear sensors (i.e the new ones that I fitted !)
    VAG COM indicates all the wheels are reading the same speed.
    Tried to do an output test but am getting a few problems:
    - either "no response from controller" or
    - says tests complete but nothing appears to have happened or
    - nothing seems to happen at all !
    I'm new to VAG COM - am I missing something ?
    Also - I cant access any groups in Basic Settings, I get "group not available message" on any group.
    I've replaced the ECU but it could be faulty so will look for another similar car to do the swop
  34. #33
    "Stick a V8 in it!"
    11,840
    Post Thanks / Like
    Intermittant faults on sensors you have replaced could indicate that the reluctor on the back of the brake disk (FWD) or on the CV joint (Quattro) is worn/contaminated/rusty...
    Might be worth taking a look at them.
  35. #34
    May 2009
    Post Thanks / Like
    Has there been any progress on this problem? I've the same issue and feel it may be the ABS ECU acting up.
  36. #35
    Nov 2008
    19
    Post Thanks / Like
