AH FabricationsChris Nott
Results 1 to 13 of 13
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,065
    s4 instrument cluster in a4
    fitted some s4 clocks i got of ebay to my 1.8tqs
    they had a new dis screen fitted so figured it would be cheaper than having mine fixed
    was never keen on the white dials, so now ive got light grey with white needles
    wasnt even sure if theyd work but no probs so far
    any comments welcome
    before
    after
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,354
    I like that Kev, how did you get passed the immo?
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    nice job i like it! did you match up the mileage? if so how, also would like to know about the immobilser as well.
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,065
    cheers mark, used vagtacho cable/software to read 4 digit skc, then followed vagcom instructions to replace cluster
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,065
    vagtacho again to correct mileage, couple of 1000 miles out as you have to enter it in km and i got fed up of guessing
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    looks good!
    Lol at mileage being out though, miles to Km is a simple calculation man! miles * 1.6 = Km
    or use google calculator:
    http://www.google.co.uk/search?q=43553miles+in+Km
    TD5 Land Rover Defender build
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,065
    cheers, sat nav thats fitted in place of vent has a conversion function but id forgot about it!
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    that sav nav looks a neat install. when you get a chance post some more pics please.
    ALPINE's Avatar
    Yes its diesel, now cry u lost
    Apr 2008
    S/E LONDON / KENT
    3,086
    shexy! i wish i could change my mileage now i have the new engine!
    Now to many mods to list! Lots of power, torque and Leather!
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,065
    alpine, legally cluster mileage should relate to shell/chassis not engine and adjusting would make car seem dodgy to anyone checking mot's etc
    raz, few more pics, its a garmin nuvi 200 cheap but quite impressive, guy on audizine worked out it was a perfect fit if you pull vent out
    also it logs max speed reached which got me a telling off from mrs
    rasA4's Avatar
    Apr 2003
    Deep
    3,096
    cheers thats a neat and tidy fit is it secured in anyway to prevent theft? i suppose if they want something they will take it etc...
    also as i understand it seen the lead on fleebay for the vagtacho. is it just a matter of buying the lead loading the software, and entering the code from your old clock and entering the new code and hey presto?? sounds too easy to be this simple?
    thanks
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,065
    its a push in fit so i dont leave it in overnight, its pin protected but rather not have my window smashed for theivin gits to find that out
    vagtacho lead plugs in via obd and then you select type of instruments (vdo old for our cars) if it can connect! its press a button for the function you want, read skc, change mileage etc
    if adding a new cluster you fit new one then read skc, then switch to vagcom lead to match ecu/keys using skc you just read
    i replaced cluster in my tdi for a brand new one (ebay, old dealer stock) and i had to drive it round the block before it would let me change mileage as it wouldnt connect to clocks with zero miles on it?
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Nice i do like the S4 clocks.
    A4 Avant project now started ! see this thread ! http://www.audi-sport.net/vb/a4-s4-forum-b5-chassis/43296-bit-project-going.html
    If you think my post had a usefull purpose please say thanks
