JMB RetrofitsChris Nott
Results 1 to 19 of 19
    freegeek's Avatar
    Jun 2008
    Dunfermline
    161
    what can you see with vag-com on a S4 2.7BT
    Can you see any or all of these.
    MAF
    Revs
    Speed
    Manifold pressure
    Command Pressure
    Air intake temp (post turbo)
    Water temp
    Exhaust temp
    Oil Temp
    Lambda
    I have a customer who wants to fit a "liquid" gauge but have not tried one on a S4 before, so am not sure what will or won't work.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    i'm pretty sure all of those are available
    Not 100% sure on the last 3 though
    TD5 Land Rover Defender build
    freegeek's Avatar
    Jun 2008
    Dunfermline
    161
    Good news, if there is anyone in the Dunfermline/Edinburgh area with a B5 A4/S4 who is willing to give up 10 mins, I would be interested to hook up a liquid gauge to try it out.
    PM me if interested
    "Stick a V8 in it!"
    15,370
    My brothers in livingston and has an S4...
    He might be interested, what does hooking up the guage involve and what does it do?
    freegeek's Avatar
    Jun 2008
    Dunfermline
    161
    It plugs into the diagnostics port and then does the following.
    Features
    Main Menu
    Gauge Display
    Graph Display
    G force
    Speed timing
    Faults and adaptations
    Setup
    Sub Menus
    Gauge Display
    Engine power
    Torque
    Boost pressure
    Cmd pressure
    Mass Air Flow
    Air Fuel Ratio
    Air intake temp
    Exhaust temp
    Coolant temp
    N75 position
    Graph data
    Engine power
    Torque
    Boost pressure
    Cmd pressure
    Mass Air Flow
    Air Fuel Ratio
    Air intake temp
    Exhaust temp
    Coolant temp
    N75 position
    Missfire
    Dyno plot
    Timing Correction
    G - Force Display
    Bar Graph
    Left
    Right
    Acceleration
    Deceleration
    Speed timing
    0-60mph acceleration timing
    0-100mph acceleration timing
    Faults and Adaptations
    Display and Erase Fault Codes
    Big turbo setting for up to 500hp engines
    English and German language versions
    Imperial or Metric units
    stapo69's Avatar
    All hail the mighty quattro!
    Mar 2007
    966
    Damn, you're way too far away for me to come see you, but I'd be interested to see how well this works on an S4 too, keep us updated.
    MRC-Powerflex-Hotchkis-Porsche-Compomtive-Vredestein-034-JHM-Apikol-EBC-FK-Labree-Vibrant-Recaro
    ALPINE's Avatar
    Yes its diesel, now cry u lost
    Apr 2008
    S/E LONDON / KENT
    3,086
    thats is a cool sounding toy! is it just for S4`s or can 1.8 turbos play as well?
    Now to many mods to list! Lots of power, torque and Leather!
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    Yes, you can see all of those readings using Vagcom, although in order to show EGT readings the ECU needs to be modified.
    I'll be up in Edinburgh over xmas if you're patient!!!
    Mo power, mo problems
    stapo69's Avatar
    Mar 2007
    966
    These were originally sold for TT's, so will work for 1.8t's and various other VAG motors, the problem comes with the OBD2 port, I've tried a few OBD ran diagnostics tools like this and not many worked due to the age of my car, 1998, there were changes in the pin layout and number of pins over time, newer cars run most things, older ones not so much, can't remember dates though, 1999 onwards knowing my luck!
    And looking at racediagnostics fitment list for this, you've guessed it, the earliest they list is 1999! But be nice to try on an older model, see how it works.
    freegeek's Avatar
    Jun 2008
    Dunfermline
    161
    What year is his car, I tried an A4 1.8T B6 model today which was incompatible, I think that it will only be the B5 models which are compatible right now.
    Next year the B6,7 models will be supported.
    If it is a B5 I would be interested in meeting up.
    "Stick a V8 in it!"
    15,370
    its an early B5 97/98 model
    I'll let him know tomorrow and see if hes interested.
    Apr 2008
    northamptonshire
    50
    i have tried various obd type gauges/data logging software,only a handfull will work on audis,you need to pull the instrument cluster fuse for some to connect
    freegeek's Avatar
    Jun 2008
    Dunfermline
    161
    The liquid does not use the OBD2 protocol since it can not get info like boost info from the car. Most VAG cars up to 2004/5 use a proprietary protocol called KW1281, this is what VAG_COM uses to read block data. the liquid uses the same method.
    Jan 2004
    York
    1,656
    If you get this working for the newer models it will sell like wildfire, I'd defo have one to replace my drivers side air vent on my B7 TDI
    MY15 8V S3 Sportback with options
    freegeek's Avatar
    Jun 2008
    Dunfermline
    161
    There are just not enough hours in the day, next year I will release an update to support all of the VAG group newer models.
    I did the older ones first as it tends to be the owners of cars aged 3 to 5 years plus, that are most interested in moding, and that my car which was the test car was an older one so was easier to start with.
    GSB1's Avatar
    May 2006
    UK
    273
    Visit GSB1's Youtube Channel
    As above think you can get all those readings, with the exception of EGT on a pre facelift car. Although I beleive MRC Tuning can enable this.
    Make something suitable for a B5 S4 and I'm sure there will be lots of takers.
    Present: Ice silver B8 S4 s-tronic saloon (standard)
    Past: Agate grey B5 S4 saloon (MRC tuned)
    Hers: Volcano red 8P A3 Sportback 2.0 TDI CR 170 sport quattro
    stapo69's Avatar
    Mar 2007
    966
    So can I run one of these on my 1998 pre-facelift S4? V interested. I noticed you list em for a 1999 S4, is this for facelift only?
    Hampshire
    102
    Quote Originally Posted by GSB1 View Post
    I would be interested in this (B5 MY2000 S4)
    MY2000 Audi S4
    Ebony Pearl
    CXRacing FMIC
    RS4 Downpipes
    RS4 brakes
    Miltek Dual
    Vogtland CO
    K04's
    Lowered CR & MRC Magic......
    (RS4 ICs 4 sale - check classifed)
    stapo69's Avatar
    Mar 2007
    966
    I'm in talks with racediagnostics about how this will run on my pre-facelift 1998 S4, he gave me the details of what to check using vag-com, emailed them results of what I found, so waiting to hear back from them.
