voteforpedro
So I finally finished the O/S control arms and there is still an annoying scraping sound!!!
Here's a brief history.
- Failed on one control arm either side
- Bought a new upper front control arm from GSF
- Replaced it - I only removed the strut and the upper control arms; the lower control arms and hub and caliper etc remained in place
- Drove it around to test and I could hear a faint scraping noise at around 5 mph
This prompted me to do it properly so I bought a 12-piece kit. Finally got it all on and I can STILL hear that sound. What the hell is it? Wheel bearing? CV joint? It was fine before I started to work on it but I was a little brutal with the drive shaft...
I somehow lost two of the three large washers for the strut top mounting in the engine bay. I wonder if they are clonking around somewhere? I doubt it though, as the grinding sound sounds rotational, if you know what I mean...
Second problem - I had the door open and was turning the steering wheel from full lock to full lock to check for nasty sounds and I caught a glimpse of the sill and noticed it shifted slightly. This means the whole chassis is shifting with the turning. Only slightly but I have never noticed a car do this before... The ignition was on so the power steering was active. Is this normal???
On the plus side, the suspension felt good on my brief drive round the block. Hit a few kerbs and things to listen for creaking/knocking and it was quiet as a mouse.
