- Joined
- Jan 5, 2006
- Messages
- 2,847
- Reaction score
- 188
- Points
- 63
- Location
- Somewhere in the Howardian Hills!
Hi,
Recently purchased a 1.8T Sport, 2000 'W' reg.
Did a vag scan and the following faults have come up:
VAG-COM Version: Release 311.2-N
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 4B0 906 018 AA
Component: 1.8L R4/5VT 0006
Coding: 04001
Shop #: WSC 06335
2 Faults Found:
17524 - Oxygen (Lambda) Sensor Heating: B1 S1: Open Circuit
P1116 - 35-00 - -
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 AB
Component: ABS 5.3 FRONT D00
Coding: 0273004281
Shop #: BB 24548
2 Faults Found:
00290 - ABS Wheel Speed Sensor: Rear Left (G46)
35-00 - -
00597 - Wheel Speed Impulses: Deviation
Address 08 -------------------------------------------------------
Controller:
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 920 980 A
Component: B5-KOMBIINSTR. VDO D11
Coding: 00444
Shop #: WSC 00000
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ AUZ7Z0Y1345191
1 Fault Found:
00562 - Sensor for Oil Level/Temperature (G266)
27-10 - Implausible Signal - Intermittent
Address 25 -------------------------------------------------------
Controller: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 35 -------------------------------------------------------
Controller: 8D0 862 257 E
Component: CV-Pump, Alarm, RC D13
Coding: 13130
Shop #: WSC 06335
No fault code found.
Address 45 -------------------------------------------------------
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 06335
Address 56 -------------------------------------------------------
Controller: 4B0 035 186 E
Component: Radio 0001
Coding: 00017
Shop #: WSC 06335
End -------------------------------------------------------
Is the Lambda sensor the on which is visible just below the air box? If so, where is best place to buy another or is there and upgraded one i can purchase?
As for the ABS, im going to visually check the abs ring/sensor first.
cheers,
Dan
Coding: 04001
Shop #: WSC 06335
2 Faults Found:
P1116 - 35-00 - -
Coding: 0273004281
Shop #: BB 24548
2 Faults Found:
35-00 - -
Controller:
Coding: 00444
Shop #: WSC 00000
1 Fault Found:
No Faults Found
Coding: 13130
Shop #: WSC 06335
Coding: 00101
Shop #: WSC 06335
Coding: 00017
Shop #: WSC 06335
cheers,
Dan
