EM TuningAH Fabrications
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    windscreen misting up!
    is the b5 bad for misting up in cold weather?mine seems to be fairly bad and takes a while to clear.the carpets are all dry so i cant see why it would be like this.
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    There is a drain under the battery which can block holding water which can cause probelms and also where the polen filter is.
    I have never had problems with my a4 misting up before do you have climate?
    A4 Avant project now started ! see this thread ! http://www.audi-sport.net/vb/a4-s4-forum-b5-chassis/43296-bit-project-going.html
    If you think my post had a usefull purpose please say thanks
    27,120
    yeah check all holes through firewall to the engine bay, I had a trim of under the steering column on my 8L & gave me condensation & ice on inside but put back & resolved, funny huh.
    May 2008
    perth
    1,197
    it has climate but not working at the moment.ill check about the battery and see if its dry.
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    under the battery and arround the polen filter tray.
    A4 Avant project now started ! see this thread ! http://www.audi-sport.net/vb/showthread.php?t=43296
