Just thought I would share some eye candy with Audi-sport forum members.This time around the 12V lump was outdated and had to go so a 24V was on call.What you are about to witness is the birth of JDM destruction....no more will the people talk about Supra's or Skylines....its time for A4's and Passat's!
As you can see Javad & crew @ 034 really go balls out when it comes to this type of work and I am proud to be affiliated with them.
Enjoy!
Enjoy!
2931cc 24V Engine said:Project Specs:
ENGINE:
* Lower Half : The Block & Oiling system
- BDF Block bored to 83mm + align honed Main's
- 83mm 9.0:1 JE Pistons
- 90.3mm OEM Crankshaft
- 034 Motorsport Forged Rods + ARP bolts
- ARP Main studs
- 034 Motorsport ARP head studs
- 034 Motorsport Coated connecting rod & Main bearings
- 034 Motorsport VW Touareg modified oil pan
- 034 Motorsport Custom 12-lb Aluminum Flywheel
- 034 Motorsport Custom starter Motor
* Upper Half : The Head
- R32 Cylinder Head - Given 034 Motorsport Stage-3 porting Job
- Stock Intake Valves
- Stock Exhaust Valves
- 034 Motorsport High-Rate Valve spring & Ti Retainers
- OEM Lifters
- Techtonics Tuning 264/260 Camshafts
* Ignition,Turbo,Intake & Fueling System:
- 034EFi Stage IIc SEM system +4Bar Map sensor
- (6) 034EFi HO Direct Fire Coils
- 034 Motorsport Plug Wires
- Garret GT4508R Turbocharger
- 034 Motorsport Tubular manifold
- 034 Motorsport Oil + Coolant supply/return kit
- TiAL 44mm Wastegate
- TiAL 50mm Blow-Off Valve
- 034 Motorsport Custom intake manifold
- Mustang 75mm Throttle Body
- 034EFi VR6 Fuel Rails
- 034 Motorsport Fuel Pressure Regulator
- (6) PRIMARY - Seimens 630cc Injectors (stock location)
- (6) SECONDARY - RC Engineering 1000cc Injectors
- (2) Bosch 044 MS Fuel pumps
