Sky InsuranceEM Tuning
Results 1 to 20 of 20
    ALPINE's Avatar
    Yes its diesel, now cry u lost
    Apr 2008
    S/E LONDON / KENT
    3,086
    my HID kit dont fit :(
    bulbs wont fit on the holes my after market lights must not be H4
    Now to many mods to list! Lots of power, torque and Leather!
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    I would bet its H1 on them lights mate
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,347
    does it have seperate mains and high beams?
    Standard facelift headlamps use H7 for main and high, as did the old pre-facelift bosch units i had fitted originally.
    TD5 Land Rover Defender build
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,082
    Was just about to say the same as above. Don't think you have H4's in the lights you have.
    I know my standard pre facelift lamps were H4 but my facelift items are H7 for the Hi and low beams
    Life begins at 140mph
    www.passionford.com
    "Stick a V8 in it!"
    15,347
    oranoco i presume you pre-facelift lamps were without fogs?
    Seems that the ones with fogs built in had H7's and a H1 for the fog and ones without had H4's
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,082
    Yeah, no fogs on mine mate. Still don't have foglights now either lol, another thing for the "to do" list
    www.passionford.com
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    Yep i have seperate high beam etc. Propper pissed today.. my new vista Pc wont work properly (no suprise there) my dump valve aint turned up, and my HID kit will not fit!! MMMEEHHHH!!!!
    diesel-a4's Avatar
    Stoned As Fuk
    162
    i have a 98 A4 pro face lift i believe and am after new lights - point me in the correct way folks.
    the just fronts for now, incl lamps. whole kit am after for the front
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    alot of the aftermarket lights seem to be H1 for some reason
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    gutted wanted hids for ages! can ya get H1 hid kits?
    jcb
    Sep 2005
    uk
    4,077
    you bought a Vista PC!? well that explains your lights,
    those things will infect your life with badness!!
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    had no choice mate!! needed a new pc and ya cant buy a xp pc any more! i got Acer commin round to fit a new mother bored as they think mines faulty!
    "Stick a V8 in it!"
    15,347
    TBH vista really isnt that bad. Its a bit different and it needs a decent amount of RAM to run nicely but then XP was exactly the same when it was released.
    The problem however is that a lot of companies are selling it on machines that basically cant run it properly. Mainly because Microsoft has discontinued XP and therefore only Vista is available for new machines, regardless of their capabilites.
    Any vista machine needs 2gb of ram to run nicely, and i'd also recommend a dual core CPU as a minimum.
    At the end of the day, if you try to run XP on a P3 with 128mb ram (which were still being sold when it was released) it'll also run like a sack of crap!
    Seems in this case its actually a hardware failure anyway, so not vistas fault at all!
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    my pc is a intel dual core Duo, 3.60ghz each so thats 7200 total cpu power!
    3k ram.
    i think its just bad luck tbh.. theres always a runt of the littler and i think i ended up with it!! just my luck init!! lol
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    I can supply you with XP at the weekend IT hapens to be my bread and butter Motherboards are common on Acer i have replace a couple for friends they are very good PCs though
    Also 4gb RAM min in Vista PC i recommend i have it and it just works how i would like it
    A4 Avant project now started ! see this thread ! http://www.audi-sport.net/vb/a4-s4-forum-b5-chassis/43296-bit-project-going.html
    If you think my post had a usefull purpose please say thanks
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    yes you can get H1 bulbs and kits there usually cheaper than the hi lo H4 kits too
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    Quote Originally Posted by Markey View Post
    cool mate.. ill keep that in mind... ill give vista another go after new m/board! if its still a C**t ill be on your case!
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    np make sure you have the service packs installed for vista as well they take an age to install but they do actually make some changes.
    A4 Avant project now started ! see this thread ! http://www.audi-sport.net/vb/showthread.php?t=43296
    Jul 2007
    Essex
    400
    Yep you can get H1 HID bulbs for your kit, you can get them fron ebay i think they are around 40 for a pair of bulbs. Just make sure they have the right connectors on for your kit, i think they are quite generic.
    Ming Blue A4 B5 RS4 Replica (SOLD)
    T28 Kit (SOLD)
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,389
    I have just got a macbook blows the PC out of the water, still use PC's on a daily and have them at home but lovin the Mac experience
    2001 S3 (AMK)
    AEM WMI Kit, Black Silicone Hoses, Badger5 TIP with Cone Filter, AH Fabrications FMIC, Relentless Manifold Downpipe & Sport Cat, Miltek Cat Back Exhaust, VAG Aero Wipers, Forge FMDV008 Re-Circ, Revo Stage 2 Remap with SPS+ Tweaks, 2.0 TFSI Coil Pack Mod, B&M Short Shift, RNS-D Retrofit, Brembo & B5 2 Piece Rotor Conversion
