Chris NottMonster Motorsport
Results 1 to 7 of 7
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    abs module problem
    when the abs module goes funny is it the module under the rear seat or the abs pump under the bonnet?
    dieselfitter251's Avatar
    Blow ma own trumpet?
    Jun 2007
    High 'C's
    1,130
    If you've got a non-quattro car then it'll be the module under rear seat. Got a vagcom? Check for codes, it is possible that the pump could have failed but unlikely.
    Ford Mondeo 2.0i Durtec Ghia X Estate
    Leather / Dog Hair.
    Dieselfitter 251
    A4 avant '97 1.9tdi q
    a.k.a. STINKY
    [B]250k!
    ..she's gooooonnnne!!!!
    May 2008
    perth
    1,197
    its a facelift quattro sport.the light comes on for a bit then goes out for a bit.had it on a diagnostic thing and it couldnt communicate with the abs or something.
    Jun 2007
    High 'C's
    1,130
    If it's a quattro then the module will be attached to the pump in the engine bay. I don't think you should have anything relating to the ABS under the rear seat? I may be wrong as I have a pre facelift quattro sport. Are you getting an error code at all?
    Leather / Dog Hair.
    Dieselfitter 251
    a.k.a. STINKY
    [B]250k!
    May 2008
    perth
    1,197
    i couldnt communicate or something and from what others have said thats what happens when its the module.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,354
    I am sure my control module is at my ABS pump on my 2wd 98. As i connected the wires there when i put the traction control on
    Jan 2007
    65
    the module will be bolted to the pump, it's the yaw sensor under the rear seat.
