Sky InsuranceEM Tuning
    Dec 2007
    14
    Airbag light on....
    Well the airbag light has come on , had codes read by a mate , its a faulty igniter , he thought that the pins on the seatbelt pretensioners could be a little corroded , so have had the B pillar trim off , cleaned the pins up in the plug , put it back together . The light is still on .
    Has anybody else had this problem ? Or is htis a common fault , any help would be appreciated
    951
    951's Avatar
    Feb 2007
    North east
    493
    Its usually the conector under the drivers seat that causes the problem.
    A4 Avant 1.8T Sport (183 bhp).
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,824
    And you will have to use VAGCOM to reset the air bag as it will not go out until it's reset even if you fix it.
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    also AndyMac kindly pointed out to me that If you dont deal with the light and if you have any other airbags in the car they will not work until you have cleared the warning light.
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
