Volks AutosChris Nott
Results 1 to 20 of 20
    griswold's Avatar
    336
    Reversing Camera power
    Just fitted a camera to the back of my a4.
    Drilled lower plastic trim of bumper ran wiring along tow hitch wiring up into car.
    Now need to connect to power permantly, tested first works fine but got bulb errors.
    Thinking of using the cable for the tow hitch which i dont use instead of tapping into revsing light, its a 7 pin bosal one that swings down.
    Anyone know which wire i should use?
    A4 1.8T Quattro sport
    A6 2.4 Avant SE
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,355
    You got a pic of it fitted? As i may fit my one and use the headunit to display the image cso i can,lol
    griswold's Avatar
    336
    A little off centre due to hidden tow hitch.
    Easiest place i thought without too much damage.
    Had one before it has red leds which light up in the dark too.
    In bottom pic leds are a bit light but not that bad its the photo.
    Ran cable to head unit just need to sort the power now.
    A6 2.4 Avant SE
    ALPINE's Avatar
    Yes its diesel, now cry u lost
    Apr 2008
    S/E LONDON / KENT
    3,086
    its not in the middle!!
    Now to many mods to list! Lots of power, torque and Leather!
    Apr 2004
    12,355
    I am looking to mount mine more under the valance out of sight except from further behind etc.
    Shame you had to mount it to one side for the towbar
    griswold's Avatar
    336
    Quote Originally Posted by alpinehead View Post
    Like i said its off centre! there is a detachable tow hitch behind with a swing down socket thats in the centre.
    The image on screen looks fine so it doesnt make any difference really.
    In one of my other cars had one fitted just under rear passenger lamp as the drivers side had the lock so looked quite even. That looked better, its really the only place i could fit it.
    A6 2.4 Avant SE
    griswold's Avatar
    336
    Quote Originally Posted by Byzan A4 View Post
    Was looking at one that is rectangular with a bracket to mount like you said.
    Would have to make somthing to fix to or would be to far back and would probably be darker?
    This one only cost 13 del next day. with 5m video cable and power lead too.
    Anyway help with the power supply?
    A6 2.4 Avant SE
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    im sorry.... i must admit i just read title and looked at pics.
    ill get my coat...
    griswold's Avatar
    336
    ill get my coat...
    No problem, Get your coat on and come round and sort the power for me
    A6 2.4 Avant SE
    Jan 2007
    Hampshire
    1,155
    I used the camera mount from a Q7/A6 for the install in my A4 (B7). For power I just ran a wire alongside the video cable to the headunit to pick an ignition live feed.
    A6 3.0 TDI.
    griswold's Avatar
    336
    Wow! that is small.
    May have to run up to front, but would rather use the tow hitch wiring if I could.
    Thanks for Help
    A6 2.4 Avant SE
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    ( For power I just ran a wire alongside the video cable to the headunit to pick an ignition live feed. )
    thats probably what id do if i couldnt get it from reverse light,cant you alter resistance to stop bulb fault.
    how you veiwing it on your screen, i thought youd only want it coming on automaticly when engaging reverse not on all the time and having to select it manually.
    LOTS DONE, LOTS SPENT !!!!
    Apr 2004
    12,355
    I like that smal camera, prolly runs at 1000 knowing audi,lol
    griswold's Avatar
    336
    Quote Originally Posted by 1wheelonly View Post
    Thats why i want to use the tow hitch thought it had a reversing output and are already wired to avoid bulb faults.
    Have fed power cable with tow hitch wiring into the boot where it is all connected but need a little help with choosing a wire? cant seem to find any info on it.
    A6 2.4 Avant SE
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    try a multi meter, see if any of the wires are dead and then test them again once reverse is selected
    Jan 2007
    Hampshire
    1,155
    It was easier for me as the B7 passes the reverse signal over CAN. Camera (140 from Audi) is connected to CANBUS and auto switches perfectly.
    A6 3.0 TDI.
    Apr 2004
    12,355
    Unless you have the 2 sockets fitted there wont be a perm live at the towbar.
    Do you have the both?
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    Ok you need ignition live for camera and a feed from reverse to the rverse input on headunit to make it switch on auto , ive fitted many of these with no faults with bulb warnings etc
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    griswold's Avatar
    336
    Quote Originally Posted by andybnwc View Post
    I'm splitting my av input on head unit with incar freeview so i can watch DAVE when in work on my break.
    So need it to work only when i put in reverse not switch to av input.
    Not 100% sure what you mean by reverse input on headunit?
    Sorry 12hr shifts are making me tired and thick.
    A6 2.4 Avant SE
    26,722
    Quote Originally Posted by griswold View Post
    Classic quote, lol
