Volks AutosEM Tuning
Thread: Self Centering?
    CraigG's Avatar
    May 2008
    188
    Self Centering?
    Just a quick query...
    We fitted new front suspension arms and front shocks and springs to my S4 today and after putting it all back together we seem to have lost the self centering on the steering.
    We changed the track rod ends too, so the tracking is likely out (we only counted the turns off and on), but ive never seen tracking causing that much of a loss of self centering before...
    Is it likely that getting the tracking done will sort it, or could something else be up?
    Will post some pics of the work in a bit.
    Imola S4 - Bilstein B6 + Eibach Prokit, Anthracite BBS Pescara 18x7.5"
    Jul 2008
    Birmingham
    629
    Quote Originally Posted by CraigG View Post
    Hi. I'm in the middle of changing the control arms and I've only removed the a strut and upper control arms on on side - haven't removed the tie rod end - and the steering wheel is way off.
    Must be something more than just the tie rods.
    HTH
    A4 1.8TQS
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,361
    Once the geometry is set, you will be ok. Did you fit lowered springs etc as that affects centering action slightly
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,949
    yer its on eibach "pro kit" springs for a 2.5 TDI Quattro
    Its lowered it a good 30mm over the "nose up" look it had before, and it now sits about 10-15mm lower than my standard 1.8T sport.
    Just need to get it in for an alignment session and it'll be all good then hopefully!
    TD5 Land Rover Defender build
