EM TuningJMB Retrofits
Results 1 to 8 of 8
    Jul 2007
    Leicester
    456
    Grounding issue on a 1.8T?
    Just wondering if anyone hear has had a similiar issue and what to look for?
    with the long standing saga with my car it appears the car wont even start and the immobiliser light keeps flashing! tried both keys to eliminate that issue as i had it previously.
    im going to have to start from the bottom up and ive been told to check the grounding? before is start looking at a new ECU and other things.
    what cables or things to look for and what to do to fix it?
    any help and suggestions appreciated!
    Dan
    custom powerflow Exhaust, Hybrid K04, S4 clutch, Autospeed FMIC, Blue Silicon pipes, ATP Exhaust Manifold, ECS Tuning Adjustable 5BAR FPR +Gauge, DefiLink Boost Gauge, Meyle HD control Arms, Koni Shock + Eibach springs, ECS tuning brakes stage 2v2, APR R1 Divertor Valve, CUSTOM DNA Tuning remap!
    27,114
    well I dont know what you've done so far, I assume you've vagged car already if not then do it asap, checked the barrel connections etc as uses induction for the electrical field to make the immo chip work for car starting, if cant read the chip then thats the cause, sounds to me like the barrel tbh as immo light suggest when being turned over it cant get a reading from the chip.
    Have I just repeated myself or what @1am, lol
    Jun 2003
    World of my own
    9,813
    Have you tried moving the steering column up & down? On B5's there's a common issue with the reader coil wire picking up interference from other wires in the loom and not reading the ignition key properly. Simply moving this wire away from the others fixes the issue.
    the dreaded immobiliser thread
    Alex Turner
    Jul 2007
    Leicester
    456
    thanks for the suggestion, been too busy at work today didnt get a chance, will get the VAG out and try the steering column trick.
    thanks!
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,385
    immo light flashing basically tells you that the immo is killing the start.
    Once you get vagcom on there it should hopefully tell you why its killing the start.
    Have you changed the engine ECU or instrument cluster at all?
    TD5 Land Rover Defender build
    Jul 2007
    Leicester
    456
    nop not since ive had the car.
    Jul 2007
    Leicester
    456
    Heres the Vag Report.
    Chassis Type: 8D - Audi A4 B5
    Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
    Mileage: 142320km/88433miles
    Address 01: Engine Labels: 058-907-55x-AEB1.lbl
    Part No: 8D0 907 557
    Component: 1,8l R4/5VT MOTR HS D05
    Coding: 04001
    Shop #: WSC 00000
    2 Faults Found:
    01247 - Activated Charcoal Filter (EVAP) System Solenoid Valve 1 (N80)
    26-10 - Output Open - Intermittent
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 35-10 - - - Intermittent
    Readiness: N/A
    Address 03: ABS Brakes Labels: 4D0-907-379-ABS.lbl
    Part No: 4D0 907 379 D
    Component: ABS BOSCH 5 7402
    Shop #: BB 37402
    No fault code found.
    Address 08: Auto HVAC Labels: Redir Fail!
    Part No: 8D0 820 043 H
    Component: A4-KLIMAVOLLAUTOMAT_D65
    Coding: 00041
    Shop #: WSC 06435
    1 Fault Found:
    00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
    30-00 - Open or Short to Plus
    Address 15: Airbags Labels: 8A0-959-655.lbl
    Part No: 8A0 959 655 B
    Component: Airbag V AUDI D00
    Coding: 00766
    Shop #: WSC 06334
    1 Fault Found:
    00532 - Supply Voltage B+
    07-10 - Signal too Low - Intermittent
    Address 17: Instruments Labels: 8D0-919-0xx-17.lbl
    Part No: 8D0 919 035 M
    Component: B5-KOMBIINSTRUMENT__D10
    Coding: 00442
    Shop #: WSC 00751
    Address 25: Immobilizer Labels: None
    Part No: 4A0 953 234
    Component: IMMO AUZ9Z0T2715661 D77
    Coding: 00000
    Shop #: WSC 00000
    1 Fault Found:
    01176 - Key
    "Stick a V8 in it!"
    15,385
    01176 - Key
    http://wiki.ross-tech.com/index.php/01176
    have a look there. (although the battery stuff is ****e as the RFID tag doesnt use a battery, it receives its power from the radio signals coming from the barrel)
