EM TuningMonster Motorsport
Results 1 to 17 of 17
Thread: ABS issue.....
    dieselfitter251's Avatar
    Blow ma own trumpet?
    Jun 2007
    High 'C's
    1,130
    ABS issue.....
    Hey folks. Had a problem with my ABS, got it scanned courtesy of a local independant VAG specialist who said my ABS module was goosed. Sent the module off to BBA-reman to get sorted (-40 quid )who have contacted me to say there is nothing wrong with the module . Now I don't doubt the guys who checked the car out but if they got a fault code which said it was the module and then the module turned out to be fine, what is it likely to be?
    Would a problem with the pump throw up a module error or would it just be down to the sensors being knackered..
    I've no fault codes to list (sorry), don't have my own vagcom so it's going back on the computer this week. Incidently, the dash board error message was red flashy symbol with the 'Warning. Fault in ABS system message'. Any ideas appreciated.
    Ford Mondeo 2.0i Durtec Ghia X Estate
    Leather / Dog Hair.
    Dieselfitter 251
    A4 avant '97 1.9tdi q
    a.k.a. STINKY
    [B]250k!
    ..she's gooooonnnne!!!!
    Oct 2007
    2,597
    Wiring (least likely) or sensor (most likely).
    PW-Motorsport's Avatar
    Jun 2006
    Pembrokeshire
    389
    What are the symptoms of the fault?
    The ABS units do fail on the A4/S4`s however they will throw up a fault code as will a faulty wheel sensor.
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    Ive had a fault on the abs for a while and cleared some wheel sensor codes but now i have had the following code . I pressume the pump is gone again but im sure i got a different code last time
    Address 03: ABS Brakes
    Controller: 8E0 614 111 A
    Component: ABS/EDS 5.3 QUATTRO D00
    Coding: 0273004284
    Shop #: BB 24334
    1 Fault Found:
    65535 - Internal Control Module Memory Error
    00-00 - -
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    Oct 2007
    2,597
    The killer of the hydraulic pumps is moisture-laden hydraulic fluid, the internals corrode, and seize up.
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    has anyone tried that online repair guide thing?
    Jun 2007
    High 'C's
    1,130
    Got me thinking..
    Quote Originally Posted by Siena View Post
    I may have been neglecting my brake fluid chages... this could be part of the problem... I'll get back to ya'll with some fault codes Wednesday night for a wee bit of advice...
    Leather / Dog Hair.
    Dieselfitter 251
    a.k.a. STINKY
    [B]250k!
    Jun 2007
    High 'C's
    1,130
    Quote Originally Posted by PW-Motorsport View Post
    Symptoms are non-abs braking and the red warning symbol from about 1/2 a rotation (of wheels) in either direction.
    Leather / Dog Hair.
    Dieselfitter 251
    a.k.a. STINKY
    [B]250k!
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,907
    could be a wheel sensor, although when we were driving around in ours without a trigger wheel fitted to the rear disk it didnt notice the fault until we reached about 10-15mph, if you braked before then the ABS kicked in and the pedal pulsed as i presume it thaught that rear wheel had locked up.
    You really should spend the couple quid and get yourself a vagcom lead, they are invaluable on these cars and saves a lot of hassle if you can quickly nip outside and check things like this!
    TD5 Land Rover Defender build
    Jun 2007
    High 'C's
    1,130
    So, fault code readers then....
    Yes, you are right of course. So what's best then, lead and software to hook up to the pooter or just one of those 16 pin hand held fault code readers thingies you can get off ebay?
    Leather / Dog Hair.
    Dieselfitter 251
    a.k.a. STINKY
    [B]250k!
    "Stick a V8 in it!"
    14,907
    My ebay lead was about a tenner, vagcom is free and the free version will do basic things like reading fault codes.
    Its possible to make it do more too.
    If you dont have a laptop it might prove problematic, although again you can probably buy a cheap old laptop off ebay for 30-50 quid (infact i'll be listing an old Dell P3 Laptop pretty soon if your interested)
    Doing that will give you a much better solution than one of the handheld readers too!
    Jun 2007
    High 'C's
    1,130
    Cool. Got a laptop. Anything to watch out for on the USB leads.. I have been looking and they're listed from about 10uid up to 40.... And I get the software from Rosstech I believe?
    Leather / Dog Hair.
    Dieselfitter 251
    a.k.a. STINKY
    [B]250k!
    Oct 2007
    2,597
    Serial VAG-COM leads are better.
    USB ones may be more modern, but they're prone to moving, and can give inaccurate readings.
    Jun 2007
    High 'C's
    1,130
    Cheers Siena...
    ...Incidently. Got the dampers on. Not had a real good drive yet but the car already seems more stable. Will update you when I get out for drive..... Full geometery check courtesy of Carlise Audi on Friday and that will be the end of a rather expensive , but necessary shopping list. (apart from this ABD issue of course!)
    Leather / Dog Hair.
    Dieselfitter 251
    a.k.a. STINKY
    [B]250k!
    Jun 2007
    High 'C's
    1,130
    ok... just bought a serial vag-com cable.. watch this space for loads of error code questions!!!!!
    Leather / Dog Hair.
    Dieselfitter 251
    a.k.a. STINKY
    [B]250k!
    audinary's Avatar
    Aug 2008
    Frinton-On-Sea
    646
    Ooh, I like the idea of Free. But free from where? I have tried the search thread but got so many results I don't have time to trawl through them.
    I just wish my laptop had a serial port not loads of USBs.....
    I'd love a bit of VagCom, From whence might one procure a FREE! copy?
    '98 Santorin Blue 1.8t Sport
    Jun 2007
    High 'C's
    1,130
    Erm you can go to ross-tech's site. http://www.ross-tech.com/vag-com/download/
    Leather / Dog Hair.
    Dieselfitter 251
    a.k.a. STINKY
    [B]250k!
