Just been cleaning my MAF sensor. Is it possible to get the mesh bit's off either end? Do they come off? Is the mesh only on the diesel MAFs? Cheers for any insight.
You should be able to remove the actual sensor from the housing. I believe there are 2 torx screws that need to be removed, the sensor will pop out ofter that making it easier for cleaning.
