Monster MotorsportBadger5
Results 1 to 22 of 22
    a4quat's Avatar
    Aug 2006
    middlesbrough
    366
    rubber door trims
    Has anybody replaced these because my o/s/f and rear are coming away from the clips and ive been told i need to buy the trims and clips from the dealers, is this right and if so how much am i looking at to buy them?
    03' S4
    00' A4 1.8TQS (sold)
    Seat Ibiza GTI (track day car) (sold)
    Seat Leon (her car)
    DRZ 400S
    Jan 2004
    York
    1,656
    I've just replaced mine. They weren't peeling away as such but they were rusting to bits underneath.
    The clips will be ok as they are plastic. The trims are held in at the front of each door by one screw... once thats un done they will either slide back and off of just crumble away. Audi charge me the following;
    Fronts 18.47 +VAT each and rears were 13.68 +VAT each.
    N.B Don't pull the trims away from the door or you'll break the plastic clips. Also when you buy the trims they don't come with either new screws or clips.
    MY15 8V S3 Sportback with options
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    Bridgend, South Wales
    617
    If you are changing the trims then do buy a few spare plastic clips, I did when I replaced my door trims; the old clips didn't seem to want to hold the new door trim on as tightly as I'd have liked, with new fixing clips it wasn't a problem.
    IIRC the clips were only about 30p each anyway..........
    '99 Ming Blue A4 Avant TDi SE 110 + Dragon Performance Tuning Box
    Factory sunroof / Cruise / Aircon + Climate / Royale Blue leather
    '72 1302LS Karmann Beetle Cabrio Silbermetallic
    '63 Karmann Ghia Sunroof Coupe Pacific Blue
    a4quat's Avatar
    Aug 2006
    middlesbrough
    366
    so i just slide the trims towards the rear or do i need to find the screw first before trying to slide them?
    03' S4
    Seat Leon (her car)
    DRZ 400S
    Jan 2004
    York
    1,656
    You need to find the screw first and unscrew it otherwise the trims won't slide back. Less chance of you breaking any clips then. The screw head is at the bottom front corner of the doors on the inside.
    Oct 2007
    2,597
    Or just lose the rubber trims completely.
    They actually act as moisture traps, and the Red Terror's never too far away then...
    Road Razor's Avatar
    Tyne & Wear
    390
    Quote Originally Posted by Siena View Post
    I've been wondering what their purposes are for. But I knew it had something weather related.
    My rubber trims are currently painted. I reckon it looks alright with them on but my NSF trim is beginning to come away from the door. It's probably time to replace the clips.
    A4 2.4 V6 2000.
    Jan 2004
    York
    1,656
    Quote Originally Posted by Road Razor View Post
    I bet you it's the metal strip underneath thats rusting away rather than the clips.
    tja
    Oct 2007
    38
    Rubber door trims
    I'm sure when I did mine I got them all from VAGPARTS for about 50+vat for the set.Would recommend using waxoyl to stop metal part rusting again.
    Jan 2004
    York
    1,656
    https://sslrelay.com/s74326199.onean...ertrimkit%3D29
    65 ish including VAT and deliv so 10 cheaper than York Audi.
    Sep 2008
    186
    The advice you have been given is spot on about replacing the rubber trims undoing the screw on the inside of the door and pulling slightly to the right looking at the door from outside..I might add I have just bought my A4 back to original condition and thought it would look better to have the Rubbers painted the same colour has the car..the alternative being putting S4 ones on which are Plastic not rubber so can be painted over ok but the price is unbeleivable to do it properly..the rubber ones can be painted if the paintshop use flexi additive in the paint to keep it all flexable..to date they have been ok and look 100 times better than black...just an idea for you to think about...
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    617
    Quote Originally Posted by tja View Post
    I might be wrong about this, but when I replaced all of my door trims about 2 years ago the new VAG replacements appeared to use a very hard plastic rather than the original-style painted metal strip?
    Why the hell Audi chose to use a metal strip in the first place mystifies me though...........
    audinary's Avatar
    Aug 2008
    Frinton-On-Sea
    646
    I'm contemplating this myself. The trims don't seem to achieve anything and my metal rail mounting thingumyjig is rusted to buggery.
    I find it amazing tbh as the rest of the car is mint. Must be the special EZ rust metal used in the trims..... or they bought them in from Fiat circa 1979...
    Ditch 'em or keep 'em? Whadyareckon?
    '98 Santorin Blue 1.8t Sport
    Jan 2004
    York
    1,656
    You will need to do some body work to the lower door if you do. The plastic clips are attached to the car by metal pins, which will need cutting of, sanding back and spraying.
    audinary's Avatar
    Aug 2008
    Frinton-On-Sea
    646
    Quote Originally Posted by auroan View Post
    Yeah, I've seen a few cars driving around w/o the trims in place, (probably rusted off...), and my paintwork skills aren't exactly good. Bloody awful if we're honest....
    At least they're quite close to the door bottom rather than right in the middle... getting an Azure Blue paint match shouldn't be that hard.....
    Mar 2007
    salford gtr manchester
    564
    rubber door trims
    as anybody got any decent pictures of a car without the lower door trims on
    INDIEJONES's Avatar
    Jun 2008
    London
    19
    I've just ordered some from VAGPARTS
    Part No: 8D0853960B - 01C Covering - Plastic 12.83 + vat (OSF)
    Part No: 8D0853970B - 01C Covering - Plastic 10.93 + vat (OSR)
    Postage 6.95 + vat
    A4 QTS AJL | 18" Nouvolari Rep's |
    Nov 2007
    Quote Originally Posted by INDIEJONES View Post
    Postage 6.95 + vat
    Had a look at VAG parts but it only lists left and right, anyone know which side is OS and which side is NS?
    Nessy's Avatar
    VW + Audi mad
    Oct 2005
    617
    Quote Originally Posted by gasman 27 View Post
    With VW/Audi part numbers ,if parts are handed; the odd number part number is always the left-hand whilst the even numbered part is the right hand.Orientations are based upon sitting in the car and facing the front.....
    If I make-up a fictional part no;
    ie 8D0 123 455B-----would be lhs
    8D0 123 456B------would be rhs
    Hope this helps.
    a4quat's Avatar
    Aug 2006
    middlesbrough
    366
    Postage 6.95 + vat
    mine are ordered
    03' S4
    Seat Leon (her car)
    DRZ 400S
    Adam-D's Avatar
    Dec 2007
    wirral, merseyside
    458
    i may need to, at least 2 of mine look a little tired
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,082
    Such simple fix to make the car look a whole load better than it did with knackered tired old strips that are hanging off
    Life begins at 140mph
    www.passionford.com
