EM TuningAH Fabrications
Results 1 to 10 of 10
    Mar 2004
    15
    head light/bulb question... HELP!
    so last night i get in my car to go home.
    the headlights had been working perfectly previously in the night.
    but i got in and turned the light lever all the way up and the head lights didnt come on.
    the parking lights where on but no head lights.
    but my high beam still worked.
    but only when i held the lever myself.
    not when i depressed it to the back to keep it on without having to hold it.
    so today i popped the hood and the bulbs look fine, not burnt out or broken or anything.
    any ideas what it could be?
    im kind of low and cash and dont wanna shell out another $50 for bulbs but i think im gonna have to.
    please help!
    Nov 2003
    Wa, USA
    248
    Re: head light/bulb question... HELP!
    Did you have the keys in the ignition? The lights won't turn on unless you have the keys in the ignition.
    Mar 2004
    15
    yeah the engine was running.
    coudl it be the wiring perhaps??
    [img]/ubbthreads/images/graemlins/confused.gif[/img]
    Nov 2003
    Wa, USA
    248
    If the headlights are "on" can you turn on the fogs(front and/or rear)?
    Jul 2003
    200
    might as well get some Xenons now! last much longer more reliable and MUCH BRIGHTER!!
    Nov 2003
    Wa, USA
    248
    does your current lighting unit take H7s? or already use D2s?
    Mar 2004
    15
    when the headlights are on the on position i cant turn the fog lights on either.
    to the guy who said go for xenons, i def. would like to but im low on cash.
    if i had the money ide just go all out and change it all.
    also im pretty sure its the h7s, not positive, its a 1996 a4 2.8 2WD if that helps.
    Milton Keynes UK
    248
    I had the same prublem in my 1989 Audi 80.
    I had upgraded the headlight bulbs to 100 Watt dip and 130 Watt main. Worked fine for about 6 months and then failed.
    The problem was down to the new bulbs drawing too much current and it burnt out the connector on the headlight switch. Removed the steering cowling and soldered the wire directly onto the switch. Worked fine until i sold the car.
    Could be you have the same problem? I trust you have checked the fuses [img]/ubbthreads/images/graemlins/smile.gif[/img]
    Regards,
    Jim.
    Nov 2003
    Wa, USA
    248
    [ QUOTE ]
    Could be you have the same problem? I trust you have checked the fuses.
    [/ QUOTE ]
    That is what i was about to see if you have done aleady...
    Mar 2004
    15
    yeah i checked the fuses for the low beam, high beam, and fog lights and they are all fine.
    i think im just gonna go for some new bulbs today and hope it works.
    but thanks for all your help guys!
