Badger5Monster Motorsport
Results 1 to 11 of 11
    Apr 2004
    Ontario, Canada
    40
    Strange Noise - Sounds like BOV
    Here is my little problem. My 2000 1.8T is stock (North American model, 150hp), no mods at all. When I was driving home earlier, I notice a strange noise, its not the standard whining noise from the turbo, but instead, it sounded more like exhaust noise.. when I release the gas, I heard a light hissing noise, something similar to BOV noise... is it coming from my stock DV? Should I be worry about it?
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,675
    Re: Strange Noise - Sounds like BOV
    What is BOV noise?
    Nov 2003
    Wa, USA
    248
    I'm only guessing(hearing an eclipse GST) but when you rev up the engine and let go of the throttle, it makes like a "woooo-cheee" noise, besides that i don't know
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    there will be a slight noise as the air is being channeled back under pressure into the air box, which on some models can be heard more than normal. The turbo can also whistle a little bit, which it might be.
    Mar 2004
    USA
    275
    I'd listen to it with the hood up and a friend revving the engine. It may very well be a bad DV or a leaking hose.
    Apr 2004
    Ontario, Canada
    40
    I never heard this when I first got the car 4 years ago (as new).. so I am sure soemthing either worn out or is broken.. thanks, I will get someone to rev it up with me listening inside the hood.. if its a bad DV, how much would it cost to get it replaced ?
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    if you wanted an after market one which last a lot longer they are about 90GBP for a gooden. not sure how much the oem ones are new but i have seen them on ebay going for about 30GBP
    Mar 2004
    USA
    275
    [ QUOTE ]
    [/ QUOTE ]
    DV's:
    Bailey = Probably the most popular, serviceable, $$$
    Forge = Large (some reported fitment issues), serviceable, $$
    Forge Race = Larger than others, adjustable, serviceable, $$$
    Hyperboost = Cosmetic package, not serviceable, $$
    Hyperboost Adjustable = New, cosmetic package, may not fit S4, adjustable preload, not serviceable, $$$
    Hyperboost HX = Newest, very cosmetic package, new internals, not serviceable, $$$
    OE Bosch 710N = Basic upgrade, popular with budget-minded modders, not serviceable, $
    OE Bosch Sport 110 = MTM upgrade, same as 710N with "better" internals, $$
    $ = under $50 USD
    $$ = $50 - $150 USD
    $$$ = Over $150 USD
    <font color="red">Don't forget to check your TBB and the small hoses coming off the DV's, too. </font>
    Apr 2004
    Ontario, Canada
    40
    thanks guys, i will let you guys know what my findings are
    Apr 2004
    Ontario, Canada
    40
    Its a real strange noise, and I seems to be burning gas more than usual.. made an appointment to have it looked at next week [img]/ubbthreads/images/graemlins/frown.gif[/img]
    Apr 2004
    Ontario, Canada
    40
    So, ontop of this problem, all my locks failed too... the damn connection to the lock pump was gone.. they got me a new pump.. so anyways,apparently this problem was due to a bad BOV.. wow.. I didn't know that the stock A4 comes with BOV.. news to me, but the dealer's advisor ensure that it is a BOV i have, not a DV... can someone PLEASE tell me if its a BOV or DV in the stock 1.8T? Maybe I should start studying the Audi A4 again from beginning?
