Chris NottMonster Motorsport
Results 1 to 9 of 9
    german masterpiece's Avatar
    2nd place is the 1st loser
    paignton devon
    13
    ENGINE OVERHEATING HELP
    hi guys im just after some advice. i havent been driving my car 4 ages as got a company van now. and went to use it the other day and it was overheating quite abit, ive had my mate who is a mechanic have a look and he has taken the thermostat out and has used a radiator cleaner but still overheats a bit, do you think its worth getting a new radiator ive heard that they're not to expensive, any advice would be grateful....
    Oct 2007
    2,597
    It would help if you stated what car you have, what engine / model.
    Right now, all we can do is guess...and guess.....and guess.....
    paignton devon
    13
    erm yes soz i thought id put that on, muppet. its an a4 20v 1.8 1996 model.
    Jan 2007
    Hampshire
    1,155
    Waterpump?
    A6 3.0 TDI.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    mate recently had a vectra that was overheating and the waterpump had been fitted with a plastic impeller, impeller had basically snapped off the shaft so the pump was doing nothing...
    If its similar in design to the AEB though, check the little belt that runs between the waterpump pulley and the PAS pump, as if that went the only sign would be it badly overheating.
    TD5 Land Rover Defender build
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,917
    I'd be inclined to say waterpump.
    As has been said they use a plastic impeller which cracks and spins on the pumps shaft.
    Had it on my last A4
    Life begins at 140mph
    www.passionford.com
    mwarrey's Avatar
    Dec 2003
    Swansea
    281
    This is almost certainly what it is, quite common as well.
    "Stick a V8 in it!"
    14,900
    Yer, something i never have fitted to an engine and never will (unless it becomes impossible to get metal ones), its quite a recent phenomenon, no doubt done to save about 50p during manufacture. I've found that the better parts suppliers tend to still be fitting proper metal impellers so if you look around you should be able to find a metal bladed replacement. I'd imagine (ok hope) that the genuine audi parts still have metal blades so that might be a last resort if you cant find one elsewhere.
    paignton devon
    13
    thanks loads guys im going to have a look at that today
