EM TuningJMB Retrofits
Thread: rattle noise
    Jun 2008
    21
    rattle noise
    Hi All,
    I have a S Reg S4/B5, 127K. I have had the car for about 4 months and have started to notice a rattle noise coming from around by the CATS. I seem to remember reading about that it could be a lining inside the downpipes that could be shattered?
    I have checked the heat shields when i replaced the EGT sensors.
    any suggestions welcome.
    Rob
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    It's the lining in the exhaust manifolds which can come away. That can be catastrophic if bits of manifold get chewed up by a turbo.
    Before you start to panic though, check to make sure you don't have a loose EGT or Lambda. Saw this recently on an RS4 which had a mystery rattle coming from the downpipes.
    Mo power, mo problems
    Jun 2008
    21
    ok, will do. thanks
    Feb 2007
    Liverpool
    1,693
    Here's some more info on the issue -
    http://www.rs246.com/index.php?name=...anifold+rattle
