JMB RetrofitsEM Tuning
Results 1 to 18 of 18
    AUDI TURBO's Avatar
    Nov 2007
    YORKSHIRE
    575
    ALL FUEL GAUGES EMPTY
    i put Ł20.00 of petrol in did about 80miles and my osd shoed about 50miles left which about righ. the petrol light was NOT on and the gauge it self was just below quater. now the osd says 0 miles, petrol ligh on and gauge doesnt register any petrol?????????? i put another Ł15 in and nothing registers. help?? any ideas
    Modified primera :-)
    NineNails's Avatar
    Proud sponsor of the snack food industry
    Sep 2006
    North Wales
    579
    Hi
    It could be This
    It certainly was on mine. It may be worth also just checking the connections are ok on the fuel sender before you dive into the tank.
    Si.
    2000 1.8t quattro Sport totally standard (ish)
    AUDI TURBO's Avatar
    Nov 2007
    YORKSHIRE
    575
    checked voltage on fuel sender it was 5v is that correct
    stapo69's Avatar
    All hail the mighty quattro!
    Mar 2007
    966
    I would say it was the issue brought up above, quite common on A4s I believe. Mine does a similar thing, gets to certain points on the gauge and drops to nothing, and the DIS follows suit as they're all tied together, drive a little further and it pops back up again, and the mpg etc registers again. An easyish fix, a cheap one at least for once. Never bothered fixin it though on mine yet as I jsut got used to it. One day!
    MRC-Powerflex-Hotchkis-Porsche-Compomtive-Vredestein-034-JHM-Apikol-EBC-FK-Labree-Vibrant-Recaro
    Oct 2007
    2,597
    Faulty fuel level sender for sure.
    Min'e a bit erratic too, haven't had time to replace.
    Turbo Lag FTW's Avatar
    Hate those none insured you know who types
    Feb 2007
    Carlisle, Cumbria. Not Geordie nor Scotch!
    233
    Mines been erratic this last week, i went to tesco`s and had 30 miles on DIS and when I came out the petrol light came on and I had 5miles left, luckily i was beside the petrol station. Although I gotta admit its weird seein it lose 25miles and previously this week the needle strangely had a bit of a wobble when I was sitting idle while waiting for the wife to finish.
    Audi A4 1.8T Sport
    Feb 2007
    233
    Also I have done the same procedure on a Peugeot 405D and the black cap is hellishly tight, although sitting above a fuel tank it is understandibly so.
    Audi A4 1.8T Sport
    AUDI TURBO's Avatar
    Nov 2007
    YORKSHIRE
    575
    the point is the fuel gauges dont move at all!!!!!!!
    AUDI TURBO's Avatar
    Nov 2007
    YORKSHIRE
    575
    and the fuel sender seems ok as it voltage etc is correct. get and dashboard check etc done on wednesday. it my birthday so my treat is to repair my car
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,388
    the fuel sender doesnt emit a voltage?
    its a resistor which changes with the fuel level
    If you measure the resistance of the sender with the wiring disconnected you should see whats going on.
    1997 S4 - PPC ÂŁ999 Challenge Track Car Build
    TD5 Land Rover Defender build
    AUDI TURBO's Avatar
    Nov 2007
    YORKSHIRE
    575
    looks like a fuel pump sender problem. done a full system check on display unit the gauges are not faulty. so new sender required it must be that thin wire that has snapped.
    "Stick a V8 in it!"
    15,388
    just fix the wire
    take you about 2 minutes once the sender is out...
    AUDI TURBO's Avatar
    Nov 2007
    YORKSHIRE
    575
    You cant just fix the wire it resistance based and very thin. ordering new sender from audi. for what it costs and the pain in arse where it is i might aswell tret it to a new one. ive spent Ł1500.00 repairing this car whats a new fuel sender eh?? grrrrrrrrrrrrrrrrrr. THIS THE WORST CAR IVE EVERE EVER OWNED.
    AUDI TURBO's Avatar
    Nov 2007
    YORKSHIRE
    575
    EVERYTHING that could go wrong has.i love the car but it taking the pee now ive only just owned it a year and it practically had everything replaced
    "Stick a V8 in it!"
    15,388
    did you actually read the thread linked to above?
    The resistor is likely fine, there is a wire that attaches the moving part to the rest of the sender which wears out and breaks
    http://vader.inow.com/~drbob/fuel.html
    this link shows you what to do, might take some time, but it wont cost anything to fix.
    http://vader.inow.com/~drbob/fuel/sendingunit.jpg
    there you can see the wire, in brown, and it looks knackered. The resistor is the stripey bit on the white casing at the top of the photo, completely seperate things
    AUDI TURBO's Avatar
    Nov 2007
    YORKSHIRE
    575
    yes i did read the link the problem is mine was NOT like that my sender both old and new did not have that wire attched to it. new sender fitted and all is ok. unless they have modifed the new sender????? thanks for help guys
    maxlbrown's Avatar
    Deep Blue
    Jan 2006
    hampshire UK
    248
    AT How much did the sender cost you from the stealers.
    Mine seems to have gone yesterday. been flaky a while now does not want to work at all
    M
    A6 2.4Se Man
    Bmw 520Ise Auto
    AUDI TURBO's Avatar
    Nov 2007
    YORKSHIRE
    575
    ABOUT Ł45.00. it cured problem but now i got really odd fuel mpg Ł15.00 ive jsut got 60 mile form it and no i not bin heavy footed................ maybe new fuel filter
