Monster MotorsportVolks Autos
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,699
    Knock sensor on 1.8T
    Hey guys for a while now on vag.com my car has brought up a knock sensor code saying signal to high or something similar.
    This has been the case for the past 3 years so I dont think and hope it can not be anything serious.
    I have ordered a green plugged sensor but I also notice there is a blue plugged one as well. Does anyone have any experience with similar faults and have any info?
    I maybe should have ordered both sensors and just replaced them both?
    A4 1.8T Quattro, FMIC, Coilovers, B&M short shift, 312mm Brakes, Stage 4 clutch, Awe Gauge, Uprated antiroll bars, plus more bits. Pics Here
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,949
    i'd imagine with a knock sensor fault the ecu will retard the timing a bit to keep everything safe...
    TD5 Land Rover Defender build
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,699
    Yeah I do sometimes drive along at a steady 70 for a long time and if I put the foot down the car does not respond as well. Is like the car is then just a n/a 1.8 or something.
    Would this be the case because of a sensor fault?
    I dont ever get a check engine light.
    Jul 2007
    Leicester
    456
    Quote Originally Posted by Soupie69uk View Post
    Hi mate,
    you getting the following error?
    Address 01: Engine Labels: 058-907-55x-AEB1.lbl
    Part No: 8D0 907 557
    Component: 1,8l R4/5VT MOTR HS D05
    Coding: 04001
    Shop #: WSC 00000
    3 Faults Found:
    16716 - Knock Sensor 2 (G66): Signal too Low
    P0332 - 35-10 - - - Intermittent
    00561 - Mixture Adaptation
    14-10 - Adaptation Limit (Add) Exceeded - Intermittent
    17735 - Knock-Control: Cylinder 3: Regulation Limit Exceeded
    P1327 - 35-10 - - - Intermittent
    i replaced both of mines theres a Green sensor and a blue sensor cost 70 for both from eurocarparts. PITA to fit as there under the intake mani and the connectors are under the coolant tank!
    custom powerflow Exhaust, Hybrid K04, S4 clutch, Autospeed FMIC, Blue Silicon pipes, ATP Exhaust Manifold, ECS Tuning Adjustable 5BAR FPR +Gauge, DefiLink Boost Gauge, Meyle HD control Arms, Koni Shock + Eibach springs, ECS tuning brakes stage 2v2, APR R1 Divertor Valve, CUSTOM DNA Tuning remap!
