Volks AutosSky Insurance
Results 1 to 10 of 10
    Nov 2003
    Wa, USA
    248
    Is this a good deal....
    S4 suspension(springs and struts) for $275+shipping? around 12k miles on the suspension.
    Mar 2004
    USA
    275
    I\'m selling mine on ebay for less than that...
    It has a reserve under $190.
    I'm in the US (Philly) - of course shipping would be extra. Approximately = $50 to $70.
    Hurry, it ends today at 5:30 Pacific time!
    http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MESSE:IT
    Good luck!
    Nov 2003
    Wa, USA
    248
    Re: I\'m selling mine on ebay for less than that...
    Well actually the ones i'm buying don't have so many miles on the (40K) the ones i found only have 12K. Is it easy to install a 19mm rear sway bar?
    Mar 2004
    USA
    275
    FYI:
    Mileage has no affect on the springs; the shocks can show wear in the seals. But my seals are perfectly intact; soft and pliable. No damage whatsoever.
    Mar 2004
    USA
    275
    [ QUOTE ]
    [/ QUOTE ]
    No. Pretty much a bolt on.
    EDIT: I mean YES! It is easy.
    Sorry! Brain freeze caused a typo!
    Nov 2003
    Wa, USA
    248
    Thanks for all the info about the Springs/Shocks, i really had no idea mileage didn't affect springs. When you said that the S4 suspension would lower the car around 1.25"-1.5" depending on how settled the OE suspension was already, what does that mean. It will lower it more if it has settled longer or vis-versa?
    Mar 2004
    USA
    275
    What I meant was that over time the springs from any suspension will settle (FYI: my S4 Suspension is fully settled). Therefore, if your suspension hasn't settled, then the resultant drop, when switched to the S4 suspension, will be more (it will be a "noticeable" drop). If your suspension has settled, then the difference will be less - there will be a drop, just not as much.
    Furthermore, if an A4 has been fitted with a Sport suspension, then the resultant drop with the install of an S4 suspension will be minimal; both the A4 Sport and S4 suspensions are close in height.
    Does this make sense now?
    Nov 2003
    Wa, USA
    248
    Yes crystal, now I'm just waiting for the springs to arrive.
    Nov 2003
    Wa, USA
    248
    Totally blew my mind that you said you were the one selling the S4 suspension on Ebay. If i were to win the bid for the item, would my stock struck towers fit with the S4's?
    Mar 2004
    USA
    275
    EDIT ^ EDIT ^ EDIT ^ EDIT
    [ QUOTE ]
    Good luck!
    [/ QUOTE ]
    <font color="red">EDIT ^ EDIT ^ EDIT ^ EDIT</font>
    MY BAD!
    The auction ends at 8:30 Pacific time and 11:30 Eastern time TODAY!
