Volks AutosJMB Retrofits
Thread: key fob
    disley's Avatar
    Aug 2004
    72
    key fob
    is there anywhere other than audi dealers
    i can get a replacement key and fob?
    have seen a few on ebay but does it have to be the exact same part number as mine to work?
    obviously it will need reprogramming anyway
    Standard specification is unacceptable
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    Have been told the serial number on the keyfob does need to be exactly the same to allow it to be coded to your immobiliser.
    If you don't have an immobiliser, you may be able to get others to work, ie: unlock the car.
    Mo power, mo problems
    Fraser's Avatar
    Aug 2003
    the north
    586
    you can get the fob from ebay
    take your apart and make sure you get the right one - p/n is inside it. the key breaks into 2 parts. the front end with the transponder can be opened by prising up the audi rings badge and there is a small screw inside.
    i bought this one from ebay as my blade was snapped - 12 quid from ebay and 15 for cutting the blade to match from my mechanics key
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWN:IT&ih=012
    you can also buy the whole key from ebay - costs a bit more 40- 60 pounds.
    recoding from dealer for me was FOC as I bought a full key from them at 105
    recoding on it's own at Chester Audi is 25, other dealers can charge 50 and maybe more
    the key front end with blank blade and transponder inside I bought from ebay was recoded fine by the dealer - free luckly as I had bought a full key as mentioned above.
    programming the remote to open the doors can be done as can the blade cutting, swapping the blades, and pairing up a new front end and remote. only thing as you recognise is the transponder recoding - they do all the keys at the same time.
    i had to show my drivers licence and V5C as well as a utility bill for the recoding
    disley's Avatar
    Aug 2004
    72
    I got a quote from smith knight fay audi in bolton..........185
    Fraser's Avatar
    Aug 2003
    the north
    586
    the parts as above should be no more than 105 from the dealer - they are taking the mick on the labour to recode. no more than 15mins to do it.
    Jul 2008
    Birmingham
    629
    I've being meaning to swap my key + Toad keyfob combo for one of those fobs.
    Question - you say they can code it to trigger the remote locking. My Toad alarm does not activate with the central locking, i.e. if I lock the doors with the key in the door.
    If they programmed a new fob to trigger the central locking remotely, chances are it won't activate the alarm, yeah?
    A4 1.8TQS
