Badger5AH Fabrications
    Apr 2004
    Portland, Oregon, USA
    27
    Question about S4 suspension
    I was curious as to what kind of suspension the S4's have, is it similar to what I have on my A4 which is the sport suspension? Or is it something completely different? Is it lower than a stock A4? Sorry for the ignorance, but I'm new to the Audi club......
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Re: Question about S4 suspension
    It is stonger because of the S4s engine and stiffer because of that.
    Mar 2004
    USA
    275
    Stiffer and stronger up front.............
    and lower by approximately 1.25" than the standard A4 suspension. It has to be stronger up front because the 2.7T engine is heavier than the 1.8T, but many people swap S4 suspensions onto A4's with 2.8 engines without any compromises. The S4 suspension, all in all, is a stiffer suspension (slightly stiffer than the Sport suspension). BTW: the height difference between the Sport suspension and the S4 is roughly .25 - .5 inches (the S4 being lower).
    Nov 2003
    Wa, USA
    248
    Re: Stiffer and stronger up front.............
    Would the S4 suspension on a 1.8T be fine, or only on a similar size engine, or does it matter?
    Mar 2004
    USA
    275
    [ QUOTE ]
    [/ QUOTE ]
    It will fit (B5 chassis). It will be stiffer (even more stiff up front). It will lower the car by about 1 to 1.5 inches (depending on how settled your OE suspension is at the time). It only matters if that's not what you want. Best advice, if you go with it: put a 19mm sway bar in the rear to compensate for the understeer. It will dial in the suspension better with the sway bar.
