Chris NottMonster Motorsport
    Lee Goodall's Avatar
    ..got my head together!
    Oct 2007
    UK - Midlands
    2,223
    Themostat.. f@cKIn bad luck!
    Replaced my thermostat and coolant temperature sensor after noticing the engine was taking longer to warm up on cold days and getting a fault for coolant temperature range.
    After draining the coolant I started to remove the two bolts securing the thermostat housing (plastic) and one sheared clean in half inside the hole!!
    ..So a 30 minute job turned into a 'mare. I had to drill the old bolt out very slowly which was a b!tch to do.
    Got a couple of replacement bolts cut them to size and fitted all the new parts.
    Car is heating up much faster now and holds a more constant temp which is nice.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,385
    ours had this problem when we baught it, needle wouldnt even reach 1/4 on the guage
    Didnt have any snapped bolts but trying to refit the stat upside down under the car into an angled housing really was a fiddly thing to do!
    TD5 Land Rover Defender build
    Oct 2007
    UK - Midlands
    2,223
    Yeah.. I had to create a 'hybrid' socket tool to get the other bolt out because of the angle!!
