- Joined
- Dec 12, 2003
- Messages
- 4,079
- Reaction score
- 93
- Points
- 48
- Location
- UK, London, SE
- Website
- hometown.aol.co.uk
they look so sweet. ive gone through every h4 bulb on the market im using daylight 80W/100W bulbs now and still rubbish. what can i get as direct fit as possible but will give both visual and major uprgrade on light on road. want a real crisp clear light???
2 stage bulbs? dont they use seperate H7's for mains and dip?
HID mains are a bad idea tbh, it removes the ability to "flash" people as the lights take too long to fire and also turning them on and off quickly damages the ballasts etc.
I'm pretty sure most factory HID installatins will still use halogens for the Main beam for that reason.
Doc: if your running factory HID's you should still consider swapping the projectors as afaik the projector lens is slightly different to the halogen version, and i presume the factory hid bulb wont fit the halogen projectors in the FK lamps.
If they're aftermarket HID's fitted to the normal halogen projectors then its probably worth fitting the FK's as they come and comparing the projectors before going to the extra effort of swapping them as you may find they're good enough.
