Badger5Chris Nott
Results 1 to 15 of 15
    ALPINE's Avatar
    Yes its diesel, now cry u lost
    Apr 2008
    S/E LONDON / KENT
    3,086
    what do i ask for..
    needing new ones. ill do both sides. what do i ask for and are they a ***** to change? ill do these whith the strut off as i have just orderd some coilies.
    many thanks.
    (maybe doc would help me if i gave him some beer tokens?)
    Now to many mods to list! Lots of power, torque and Leather!
    98 A4 1.8SE
    May 2008
    Derbyshire
    135
    track rod end / tie rod end.
    should be fairly straightforward as long as you are able to undo the bolts
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    thought so..... cheers for the confermation.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,384
    The kit i linked to in the other thread comes with them, but yer they are called track rod ends or tie rod ends
    TD5 Land Rover Defender build
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    sweet mate... thanks very much
    98 A4 1.8SE
    May 2008
    Derbyshire
    135
    could you not have posted this in your other thread? why did you start a new one? i didn't even know there was another thread, then i find someone already answered the question! :-/
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    lol soz.. didnt even think about it!
    GSB1's Avatar
    May 2006
    UK
    273
    Visit GSB1's Youtube Channel
    Don't forget you'll need an alignment afterwards, but if you're fitting coilovers too that's good timing to get it done.
    Present: Ice silver B8 S4 s-tronic saloon (standard)
    Past: Agate grey B5 S4 saloon (MRC tuned)
    Hers: Volcano red 8P A3 Sportback 2.0 TDI CR 170 sport quattro
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    yep plan is to get it all done at same time. never have alignment done b4, where would i go and how much roughly?
    27,114
    well def not audi as they overcharge & dont use there heads just follow the book, so if you have a even the most minutely slight buckle from some knock they dont know how to compensate with adjustments, they just have settings & thats it so if you end up driving round in circles they say "well its set as per audi says so its correct" lol, lolFind a reputable tyre place not kwik fit with a decent system thats regularly calibrated, then test drive for any pulling to the side then go back for adjustments.
    I would say 50 approx is fair, nowhere near the reported 200 from one audi dealership, but if you are doing suspension arent you getting it fitted or DIY cause fitters should have the system to do for you.
    Yes its a tie rod bush.
    GSB1's Avatar
    May 2006
    UK
    273
    Yes the dealer may well be in the region of 180-200 but some have a set price, so at their hourly rates, it works out well (for a dealer).
    Ideally find a specialist that has the correct Beisbarth machines such a specialist alignment service or VAG specialist such as AutoPS. I'd still expect to pay 80-100.
    Just an additional note, you may find the replacement tie rod end is not identical to the one you remove, when I had mine changed it appeared the part had been revised.
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    Quote Originally Posted by GSB1 View Post
    cheers for letting me know that.
    "Stick a V8 in it!"
    15,384
    You do realise that none of the geometry is acutally adjustable on a B5 bar the tracking/toe settings and the left to right camber distribution. The camber on individual sides isnt adjustable, the overall balance is only adjustable if you unbolt the subframe and move it side to side.
    That means that unless the subframe has been removed or you suspect the camber to be uneven then the only thing thats acutally worth paying money for is the tracking/toe adjustments.
    A full alignment check may highlight things that are out of spec, but they're not actually adjustable so it would just mean replacing the suspect part.
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    im getting the tracking and cambers set to my requirments. thanks to my good freind steve at chessington motors!!
    "Stick a V8 in it!"
    15,384
    and how exactly do you intend to set the camber when its not adjustable?
