Volks AutosBadger5
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    central locking pump impellers?
    does anybody know if the impellers from an early pump with one hose will go in a later pump with 2 hoses? the early pumps are cheaper and the local breakers has two so if it can be done that will be good.
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    can be done with a slight mod
    http://www.audiworld.com/tech/elec149.shtml
    May 2008
    perth
    1,197
    thats only for ones with one pipe?
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    actual pump inside only has one outlet
