JMB RetrofitsBadger5
Thread: Wierdest Thing
    Nov 2003
    Wa, USA
    248
    Wierdest Thing
    I am just wondering if anyone else has had this problem occur. For some reason my front left park light lights up(with headlights off) when i hit the brakes? On the wierder side when i turn my lights on the brake lights light up as if i were hitting the brakes. And lastly my cruise control won't go on. I'm not sure if i have like a crossed wire or something, but any advise would be great. If i can't find the problem then my last resort is to take it to a place and have them just fix whatever the problem is.
    Jan 2004
    Bristol
    87
    Re: Wierdest Thing
    I would check the terminals on the battery and make sure they are nice and tight, also check the earth strap from the battery to the chassis. If these are loose they can cause all sorts of weird electrical problems.
    Apr 2004
    Sydney, Australia
    262
    Re: Wierdest Thing
    CHECK YOUR BRAKE LIGHT BULBS - U HAVE PUT THEM IN THE WRONG WAY!!!!!!!!!!! AS YOUR BRAKE BULBS HAVE BUILT IN SIDE LIGHTS, IF YOU PUT THEM IN THE WRONG WAY AROUND YOU CHANGE THE WAY THE WHOLE CAR CIRCUITRY WORKS.
    Apr 2004
    Sydney, Australia
    262
    Re: Wierdest Thing
    No probs!
