Badger5Sky Insurance
Results 1 to 38 of 38
Thread: Under 20mpg
    Bong Water's Avatar
    In two minds
    Dec 2007
    785
    Under 20mpg
    Just worked out my mpg and its not good, I am getting just under 20 in my 2000 1.8TQS with 58K on the clock
    I used this site http://www.fuel-economy.co.uk/calc.shtml
    Fuel cost 100.16 (pence)
    Total spend 40 (pounds)
    Distance 170 (miles)
    = 19.35mpg
    Why do you think I could be getting such low mpg?
    My car had no codes in January this year, however a month or so ago the rubber pipe that connects the IC to the IM popped off, not sure why but pretty sure it was due to a loose jubilee clip on the IM, not sure if this could have anything to do with, my local mechanic thinks not but he wants 40 to read codes and I dont fancy parting with 40 right now!
    The above figures are based on tesco SUL and mixed town and motorway
    Currently doing the same with UL
    Thanks in advance
    Skint because of my car, the forums made me do it
    smitch's Avatar
    Sep 2006
    1,585
    Welcome to S4 world......
    S4.
    Bong Water's Avatar
    In two minds
    Dec 2007
    785
    Its a 1.8T!? If it was an S4 I would be happy with that MPG
    There is defo something wrong
    Z82
    Apr 2006
    Inverness, Scotland.
    453
    Depends how you drive it that is possible
    7. 2003 B6 Nogaro Blue S4 v8 quattro
    Gone but not forgotten:
    6. 1996 B5 Casablanca White A4 2.6 v6 quattro Sport
    5. 1989 B3 Maroon Coupe 2.0E
    4. 1986 B2 Red Coupe 2.2E Limited Edition
    3. 1985 B2 Red 80 Sport
    2. 1983 B2 Black 80 Sport
    1. 1984 B2 Silver 80 Sport
    Bong Water's Avatar
    In two minds
    Dec 2007
    785
    Mixed town and motorway as mentioned, just normal driving, I only put my foot down now and again its not really possible to drive aggresive.
    I should say that it was using around 20-25 a week and now that figure has gone up to 35-40 a wee, thats a huge increase and I cant afford to run it!
    Surely someone must have experianced something along these lines?
    Road Razor's Avatar
    Tyne & Wear
    390
    Something's definitely not right. Mine achieved similar figures recentl. I spent 45 (113p per litre) and only achieved 200 miles. Eventually the fuel filter was diagnosed to be the problem - it wasn't connected properly since the last service. Also the breather fuel pipe got partially disconnected for some strange reason. Anyway having fixed all that I now done just over 120 miles and still have 95mi remaining on the DIS after spending 35. 20 mile round trip a day on dual carriageways. However, I do use cruise control which I think helps.
    Nowadays due to high prices of fuel I top my car up to half-way point which gets me further as opposed to topping up to full due to fuel load. A friend I know suggested it, and I thought he was just trying to be funny - but it works. LOL.
    A4 2.4 V6 2000.
    Bong Water's Avatar
    In two minds
    Dec 2007
    785
    Cheers for the info, did vag com bring anything up to point you in the direction of the fuel filter and breather pipe?
    Road Razor's Avatar
    Tyne & Wear
    390
    Nope nothing appeared on the vagcom that suggested where the problem was.
    A4 2.4 V6 2000.
    Road Razor's Avatar
    Tyne & Wear
    390
    But I managed to smell fuel coming through the airvents while the car was stationary with the fan on. That confirms that something was leaking from the engine. Also, when I started the car droplets of fuel could be seen coming out from the fuel filter.
    Try starting your car and check for possible droplets of fuel from beneath the car.
    A4 2.4 V6 2000.
    Bong Water's Avatar
    In two minds
    Dec 2007
    785
    Ok ill try that, it has not smelled of fuel recently though and I would of noticed that, thinking of booking it in somewhere now, will be cheaper in the long run as its costing me a fortune to run at the moment
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,082
    Sounds good to me but I suffer with a medical affliction know as "leadrightfooticus" lol
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,751
    I am getting 335 miles to a tank at the moment, I have never known it so good.
    A4 1.8T Quattro
    Mar 2008
    73
    31.8mpg driven hard on a 2.4 V6, yours sounds thirsty!
    AUDI TURBO's Avatar
    Nov 2007
    YORKSHIRE
    575
    NOPE mine 1.8t and i get about 20mpg per gallon from 20pounds of juice about 120miles at the max
    Modified primera :-)
    Bong Water's Avatar
    In two minds
    Dec 2007
    785
    The key thing here is the change in MPG from when I first got it even though my commute has not changed. Its almost doubled how much fuel it uses since I first got it, I am going to book it in as I am sure there is something wrong here, I would get yours looked at too AUDI TURBO, 20mpg if driving normally is just not right
    Bong Water's Avatar
    In two minds
    Dec 2007
    785
    Booked in at Awesome GTI next Thursday for diagnostic and fault inspection
    AUDI TURBO's Avatar
    Nov 2007
    YORKSHIRE
    575
    I do 95% town driving stop starting. and im im taking medication for heavy right foot
    hiltoa's Avatar
    VAG erfahren
    Jul 2006
    on the edge
    299
    Would be interesting to see if you find anything - i'm averaging 23 - 25 mpg. I do also suffer from "leadrightfooticus" though.
    Must stop trying to spin up all 4 wheels, but it's so tempting since fitting the Southbend clutch...
    Nothing feels fast for long...
    2004 Audi Allroad 2.5 TDI L.E.
    Ebony Black.
    1991 VW Golf GTI 16v
    Tornado rot.
    Bong Water's Avatar
    In two minds
    Dec 2007
    785
    I hope they do find something TBH, for the price of the inspection I want a fault to be there!!!! I could of got it down cheaper and more local but I know Awesome will do a proper job so its worth paying a bit more sometimes
    jcb
    Sep 2005
    uk
    4,077
    i get the same...stop driving like you stole it and it comes down!
    Bong Water's Avatar
    In two minds
    Dec 2007
    785
    FFS I dont think you guys are the grip of this!!!!
    Driving it exactly the same as I always have, the MPG has dropped for sure
    Unless I am proved wrong on Thursday in which I lose 60
    Jun 2006
    17
    Since P W Motorsport (Cheers Phil) sorted my S4,I have been drivng it like it's stolen and I still get 24 MPG.
    Happy Days.
    Only problem is the Mrs saying I need an Aygo diesel or some bobbins...
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,350
    when i baught mine the thermostat was stuck open and it was doing low 20s mpg fixed that and it rose to 30ish
    the guage wouldnt reach 90 though so it was obvious there was a problem
    for a drop like that its either a leak, or CTS or Lambda is faulty
    ours will do 380-400 on a tank now (its currently on 344 and hasnt beeped yet), averaging 31ish mpg. The missus drives it quite mildly though.
    TD5 Land Rover Defender build
    Turbo Lag FTW's Avatar
    Hate those none insured you know who types
    Feb 2007
    Carlisle, Cumbria. Not Geordie nor Scotch!
    233
    I average 28.5 mpg now, thats a drop of 2.5mpg for me but it could be down to the fact I need to service her. And this time I may spend a little more on the spark plugs. Also contemplated selling her last week, with fuel escalating and my avg wage not keeping up Im gonna have to do something, but then again I could do with getting a push bike and doing some exercise lol.
    Audi A4 1.8T Sport
    Oct 2007
    2,597
    My fuel warning came up on my autocheck today.
    427 miles I got, with mixed driving.
    Range still showing a possible 35 miles.
    Car is a '96 A4 2,6L QS.
    Z82
    Apr 2006
    453
    Quote Originally Posted by Siena View Post
    Got the same car, I usually average 20mpg but had it as low as 17mpg and as high as 38mpg
  28. #27
    205man's Avatar
    May 2006
    worcestershire, uk
    1,016
    i was getting 19.1 mpg when i used to drive my 2.8 quattro sport, but since my girlfriends no drives its almost everyday she has got it upto 22.3mpg
  29. #28
    Bong Water's Avatar
    In two minds
    Dec 2007
    785
    Some helpful info, thanks all, confirms I did the right thing booking it in as I am certain there is something wrong. Hopefully its something I can replace with an uprated part!!!
    Thermostat and temp sender were replaced when I purchased the car, it also had a major service in January this year inc all filters, oil and plugs
  30. #29
    TFSI's Avatar
    Born to Fish
    South Cheshire
    531
    Quote Originally Posted by Bong Water View Post
    = 19.35mpg
    Thanks in advance
    Bloody hell our baby trucks average 24 mpg and they weigh 7.5 tons.
    1.4 T is doing 37 mpg knocking about and 44 mpg on a steady long run
    2013 1.4 TFSI S line 8V, Brilliant Red, Cruise Control, DIS, MFSW, Dual Climate, Leather, Front Fogs, 18in 5 Twin Spoke Alloys, Welly, Boot and Fishing Rod Racks.
  31. #30
    Bong Water's Avatar
    In two minds
    Dec 2007
    785
    I know its getting right on my nerves now, costing me a lorra lorra money
    Got to wait till Thursday to find out whats wrong, hope its something simple!!!
  32. #31
    Jpc
    Mar 2007
    124
    any update?
  33. #32
    Bong Water's Avatar
    In two minds
    Dec 2007
    785
    Sorry yeah, vagcom says
    MAF giving dodgy readings
    Coolant temp sensor giving dodgy readings
    Apparently this is the cause of my fuel woes
    Both being replaced on Wednesday this week so hopefully this will see the problem gone
  34. #33
    Road Razor's Avatar
    Tyne & Wear
    390
    Yeah hope that solves the fuel issues. Update us once it's fixed.
    A4 2.4 V6 2000.
  35. #34
    Bong Water's Avatar
    In two minds
    Dec 2007
    785
    Me too man! Thanks and will do. Have to say I have fallen out with the car a bit, kind of missing the old Honda reliability and high revving FWD fun
  36. #35
    Z82
    Apr 2006
    453
    Dude Jap is crap, I thought you would of learnt that after have the 4ring variety!
  37. #36
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,751
    I put 16.50 (114.9p/litre)of normal shell petrol in it the last week to last until the vpower came back in stock and I got 109miles for it. Comp said that that was 31.4mpg but working it out with the link above I got 34.5mpg. That was taking it easy.
    I put in 65.68 (53.88 litres) of vpower tonight so will let you know how many miles I get from this tank. Will take me a while to get through this tank though as the car doesnt get used that much at the moment.
    A4 1.8T Quattro
  38. #37
    Bong Water's Avatar
    In two minds
    Dec 2007
    785
    Will be worth knowing mate thanks, its getting the parts fitted on wednesday though
    Z82, had 4 Civics and they are the most reliable cars on the planet IMO, I wouldnt agree that Jap is crap, they arnt as solid and dont have the interior touches and build quality but they are so much fun, Honda and Toyota high revving engines are a right laugh, not much in the way of torque but they make up for it when they scream! Anyway if I was to change it would be next year and ill probably change my mind by then but I have definitley decided not to get any wheels and just replace my tyres instead
  39. #38
    Bong Water's Avatar
    In two minds
    Dec 2007
    785
    Had the parts fitted, car feels more responsive on the drive home, its pretty far and from what I could tell it didnt use anywhere near as much as getting there so happy days
