AH FabricationsChris Nott
    May 2004
    Buying 2001 S4 Avant
    I am looking to buy a 2001 S4 Avant with tiptronic. I have found the car. What problems should I look out for with this car? Any pitfalls with the engine? The transmission? It is a CPO vehicle. What would be some intial upgrades to consider? All replies/advice would be appreciated.
    [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Aberdeen
    153
    Re: Buying 2001 S4 Avant
    Try here, http://www.s4-mtm.com/library.htm
    Go right to the bottom there is a S4 buyers guide.
    Drive a couple to get a feel for the power delivery. The bi-turbo has a lot pipes, hoses etc. that can rupture/leak cause the car to produce less power. It would help if you completed your location. Then you might get a friendly experienced S4 owner to help look over a car for you. It is also good to find someone with a diagnostic tool to check your prospective purchase for ECU error codes. VAGCOM
    is the popular tool for this http://www.ross-tech.com/
    Good luck
    Mar 2004
    USA
    275
    I agree with Patrick.
    I'd suggest you check the TBB for any rupture or tears. Check the control arms up front, too. Other than that, go with Patrick's good advice.
