Volks AutosChris Nott
Results 1 to 8 of 8
    Hong Kong
    48
    Gearbox and Rear Diff
    Anyone done this yet? For an S4 manual 00 model.
    When changing the two, can you use the same oil or are they completely different? Any suggestions on brand name or must use Audi stuff.
    jcb
    Sep 2005
    uk
    4,070
    quaif do an LSD for the rear. I am getting one
    Gearbox and rear diff must be matched to the same final drive that is the biggest issue with swaps
    Hong Kong
    48
    sorry jcb,
    i was refering to the oil. Can the gearbox and the rear diff use the same type of oil?
    On another topic your new Quaife (think that is how you spell it) what are the advantages over the current one that I have?
    Is it worth getting the Diff upgrade and the LSD?
    http://www.stasisengineering.com/Thu...px?ID=9&VID=50
    jcb
    Sep 2005
    uk
    4,070
    not sure about the oil, would say it is pretty similar
    the LSD allows much more agressive non linear acceleration as well as just generally giving a more stable rear wheel drive.
    i find that any acceleration out of cambered or slightly uneven (especially crests) corners means I get slight slippage from the rear.
    not important but I would imagine as I up the power to the levels I am working on it is just going to get worse.
    Hong Kong
    48
    Have you installed your LSD yet from Quaife? would you recommend it over the Stasis type?
    jcb
    Sep 2005
    uk
    4,070
    not sure what the difference is tbh.
    quaife has a good rep...both pretty pricey though
    duane's Avatar
    May 2004
    uk
    142
    Quote Originally Posted by Honkers View Post
    I had mine changed a while ago, from memory you need 2 types of oil, one for gear box and another for rear diff. I went with OEM when i had it done. I remeber it wasn't cheap for the oil either.....
    B5 S4 Kingfisher Blue.
    B6 A4 Atlas Grey 1.9 TDI Quattro Sport.
    Hong Kong
    48
    I had my gearbox and rear oil changed today. You're right Duane, the oils are different. The mechanic told me he had to syphon out the last 1/2 litre from the diff because its not like draining out engine oil where it has its own plug. I used original stuff too and cost me 80quid for parts and labour.
