JMB RetrofitsVolks Autos
Results 1 to 14 of 14
    Mar 2008
    144
    2.7T CAI / airbox/ BMC-CAI help
    I've been looking at getting a induction kit for my S4.
    When i looked at my air box i noticed two sensors plugged on to the top of it (not the MAF) what are these?
    Do most induction kits account for this and incorporate it?
    Aspecilly a BMC kit because thats the one I'm ideally after.
    Any info or help appreciated.
    ALPINE's Avatar
    Yes its diesel, now cry u lost
    Apr 2008
    S/E LONDON / KENT
    3,086
    that little sensor needs to be keeped cold as they get very hot. thats all i know on them, i have a small induction pipe running purley to this sensor to keep it cool, it runs fine.
    if you look in the air box mod thread you will see pics of my induction, and in bottom left corner the tied back sensor in question.
    Now to many mods to list! Lots of power, torque and Leather!
    Oct 2007
    2,597
    The 2 sensors on the S4 airbox are the ignition amplifiers (Power Output Stages).
    My advice as per an induction kit for your S4?
    Don't bother.
    Mar 2008
    144
    Quote Originally Posted by Siena View Post
    Don't bother.
    Thanks for the info.
    The air box intake slot looks very small, has anyone managed to fit a kit on a 2.7T with no probs?
    Maybe a modded air box might help instead with a good filter.
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,841
    RS4 setup
    S4
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    I got that kit on mine , does not come with the rubber connector to the original air intake in grill also, the piping to that was rubbish and kinks when bent notice the very sharp angle
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,301
    tbh its a turbocharged engine and imo your wasting your time with induction kits etc
    by all means enlarge the intakes on the stock airbox if you feel they are restrictive, but as for "Cold Air Induction" do you really think that when your driving along with wind blowing through the engine bay at 30/40/70/90mph that theres going to be a build up of heat? Its ********, you might get some heatsoak with the car sitting stationary but otherwise forget it.
    Not to mention the fact that after the air flows along about a foot of pipework it gets dumped into a compressor and heated up to 80C or something. Spend your time/money fitting larger intercooler/s and make some larger holes in the stock airbox if you wish some extra noise (pre filter remember)
    TD5 Land Rover Defender build
    stapo69's Avatar
    All hail the mighty quattro!
    Mar 2007
    966
    I bought this set up from the states, by far the best I could find, and the only one that seem to come recommended, doug at MRC has fitted a couple, emailed him and he said they worked well.
    Uses the standard cold air intake and seals completely against the bonnet when shut.
    Not cheap by any means though, and only available from the states. Explains all on the site though, and emailed em a few times, very helpful guys.
    http://sdr-research.com/x1/intake.htm
    MRC-Powerflex-Hotchkis-Porsche-Compomtive-Vredestein-034-JHM-Apikol-EBC-FK-Labree-Vibrant-Recaro
    "Stick a V8 in it!"
    15,301
    companies can make all these claims but any experimentation they do is always biased... a pressure drop in the inlet of a whole PSI could be seen equally with a panel filter in the stock airbox with enlarged openings, costing about a tenth of the price.
    I had an air temp sensor fitted in the inlet tract on my old car just to see what kinda readings the cone filter would give without any form of shielding or ducting and sure enough as soon as you were moving at anything more than about 10mph the temps were within 1c of ambient.
    If i get a chance i'll try to get some readings from the A4 comparing the stock airbox with the stock ducting and the stock airbox with some holes drilled in it.
    Mar 2008
    144
    So very good points there by all keep them coming.
    I am stating to go towards a good panel filter and mod the air box, i also need the standard cold air feed, because it didn't come with the car when i got it.
    audivro's Avatar
    Apr 2008
    36
    Manufacturers spend the income of small country's designing air box's,Unless it is an overly restrictive airbox they really are the best way to go.Most manufacturers,audi included,design very efficient induction systems which provide good torque(probably the most influential in road use) good economy and reliability.When i tested various setups on a rolling road for my gt4 i found the airbox to be as good as if not better than the HKS,BLITZ and a CAI.The BLITZ and HKS gave 2 bhp more but that was when the airflow was at its greatest at around 6400 rpm!!!These are the open filter types and gave drops in power at all other times...although they sounded nice!The cai gave around the same torque and bhp but for the 320 it cost was no better than my airbox with a panel filter.
    So in short,standard air box,air flow modded,panel filter(non oiled type so not to fubar tha maf) and save the rest for something shiny!!!!
    mwarrey's Avatar
    Dec 2003
    Swansea
    281
    Anyone recommend a good non oiled filter for the s4 ?
    audivro's Avatar
    Apr 2008
    36
    i think the green cotton filters are still non oiled.Have'nt seen one for a while though so could be wrong.
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,841
    well this thread reminded me of the CDA/BMC I had in my old 2.8 that work real well so I had a hunt round ebay and with that snipe Auction thing I one this Link.
    So at some point I will be dropping it in.
