Volks AutosMonster Motorsport
Results 1 to 12 of 12
Thread: airbox mod ?
    AUDI@WRC's Avatar
    hows my driving call 0800-EAT-****
    Feb 2007
    84
    airbox mod ?
    has anybody done the airbox mod ?
    http://www.audizine.com/forum/showthread.php?t=190394
    AUDI A4 AVANT 1.8T SPORT
    18" RS6 ALLOYS**RS4 FRONT GRILL**RS4 LOWER GRILLS** HALO HEADLIGHTS** N75 'J'** FORGE SPLITR DUMP VALVE** SPLITFIRE BOOST GAUGE VENT MOUNTED**GERMAN NUMBER PLATES **LOWERED 40MM**CHIPPED UK REMAP**
    floyd 1.8 turbo's Avatar
    Mirror, Signal, Outmanoeuvre
    Apr 2008
    Bracknell, Berks
    630
    looks like a good idea, cant see any problems with that. Be good for me as im saving for the baby so cant afford a proper intake yet
    White B5 1.8 turbo sport
    AUDI@WRC's Avatar
    Feb 2007
    84
    me too baby due in aug !!
    Biglockie's Avatar
    Aye you know it makes sense
    Nov 2006
    cumbria
    1,030
    I've drilled my airbox in the area they have removed in the pictures. Will it not draw water in when its raining???
    AUDI@WRC's Avatar
    Feb 2007
    84
    according to all the americans they had no problems with the filter getting wet, he has used fly mesh on the wheel arch and air box just to make sure also drilled a small hole at the bottom corner of the air box for a drain just incase.
    Biglockie's Avatar
    Nov 2006
    cumbria
    1,030
    Hmmm might be worth a go then, anyone got a spare air box???
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Looking at that though some water must get into there of the tyres during heavy rain?
    A4 Avant project now started ! see this thread ! http://www.audi-sport.net/vb/a4-s4-forum-b5-chassis/43296-bit-project-going.html
    If you think my post had a usefull purpose please say thanks
    Lee Goodall's Avatar
    ..got my head together!
    Oct 2007
    UK - Midlands
    2,223
    I've done a similar mod but ran a sealed CAI into the base of the air box and down to the vent in the bumper. I've had no issues with moisture etc.
    Also smoothed the internals out of the air box.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    instead of drilling thru the arch liner etc, wouldn't it be possible/better to drill out the front edge of the airbox that points towards the headlight?
    That way your not risking excessive water ingress while still allowing more air into the airbox. I dont believe heat soak would be too much of a problem either unless your sitting stationary for a long period of time as there will be plenty airflow blowing around in that area anyway once your driving along, and compared to the roasting the turbos going to give it anyway any slight increase will be negligable!
    TD5 Land Rover Defender build
    Z82
    Apr 2006
    Inverness, Scotland.
    453
    Is this worth concidering for my 2.6i ?
    7. 2003 B6 Nogaro Blue S4 v8 quattro
    Gone but not forgotten:
    6. 1996 B5 Casablanca White A4 2.6 v6 quattro Sport
    5. 1989 B3 Maroon Coupe 2.0E
    4. 1986 B2 Red Coupe 2.2E Limited Edition
    3. 1985 B2 Red 80 Sport
    2. 1983 B2 Black 80 Sport
    1. 1984 B2 Silver 80 Sport
    ALPINE's Avatar
    Yes its diesel, now cry u lost
    Apr 2008
    S/E LONDON / KENT
    3,086
    i have done a similar mod to mine, i have a cone filter tho, as i have no heat shealing from the turbo, i just have a 4" pipe commin up from the front of car, (relocated horn) and have cut a whole in the arch, the filter sits ontop of the 4" pipe and slightly pops out the hole icut in arch. i have no drama with the wet, and it hissis like a beyatch when you floor it! (it has also made the wastegate chatter alot louder!
    Now to many mods to list! Lots of power, torque and Leather!
    ALPINE's Avatar
    Apr 2008
    S/E LONDON / KENT
    3,086
    air filter
    this is what i have done to my intake!
    UNDER THE FILTER IS THIS..... runs down to the left hand vent in bumper.
    there is a cut out in the inner arch for filter to slightly poke out
