Badger5Monster Motorsport
    Mar 2008
    Ipswichish
    127
    quick spring question.
    would std Rs4 springs fit my S4, and would there be any bennifit to fitting them? ie lower ride or stiffer?
    '99 noggy blue S4 / '84 mk1 Astra GTE turbo
    Oct 2007
    2,597
    They'd fit, they'll be stiffer, but higher at the front.
    My set-up is Eibach springs for the RS4, and Bilstein Sport dampers for the RS4 too. My front end's higher, but I expected that.
    I also know once my S8 motor, and 6-speed box go in, the front'll settle just fine.
    Oct 2007
    2,597
    Where abouts in Suffolk are you? You might be pretty local to me.
    Mar 2008
    Ipswichish
    127
    cheers mate,
    why higher at the front? is the Rs4 lump that much heavier than the s4 then?
    Mar 2008
    Ipswichish
    127
    Quote Originally Posted by Siena View Post
    I'm just the other side of ipswich from you, nr Hadleigh
    Oct 2007
    2,597
    Pretty close then, will keep a look out for your car.
    The RS4 IS a fair bit heavier than the S4, overall.
