Badger5Volks Autos
Results 1 to 13 of 13
    May 2008
    Leicestershire UK
    7
    What to look out for when buying a A4
    Hi im new here, i currently have a passat 1.9TDI quite tuned, but now i feel i want somthing faster so im going to look at a N reg A4 1.8T sport with 83000miles on the clock. Is there any odvious things i should look for apart from loads of smoke when you boot it?
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    Regular servicing essential as these can suffer oil starvation problems if not properly looked after, Also make sure cam belt done as thats costly to get done, as normal, squeeks and groans as the front suspension can groan a lot when the bushes are worn, and the bushes are part of the arms, so new ars are needed.
    Also there should be no hesistaion, and the turbo should be just about audible, but not whistling
    May 2008
    Leicestershire UK
    7
    Great thanks for that ill bear them in mind.
    jcb
    Sep 2005
    uk
    4,077
    clunking/knocking/squeaking front suspension, anything less than perfect tracking, uneven tyre wear, smoking turbo on overun and startup, black oil (old), rusting lock strip on boot, corrosion on rear door sail trim, corrosion around roof bars/ariel
    May 2008
    Leicestershire UK
    7
    Thanks would you say 1500 is a good price if non of the things you said were wrong? as its only a N plate
    Thanks again
    jcb
    Sep 2005
    uk
    4,077
    quattro?
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    1.8T quattro's only existed from around '99 so it'll be a FWD
    TD5 Land Rover Defender build
    May 2008
    Leicestershire UK
    7
    Quote Originally Posted by jcb View Post
    quattro?
    No just 1.8T 20v sport but it is low milage for year an he sad its well looked after
    Apr 2004
    12,520
    For 1500 it had better be full history, and absolutly mint condition, and under 60k or something. thats a lot of money for a 12 year old car
    May 2008
    Leicestershire UK
    7
    well its not quite 60K more like 80K it has full service history. If you think i could find a better one for the money ill keep looking.
    Apr 2004
    12,520
    80 k still good milage, go see it and haggle etc
    May 2008
    Leicestershire UK
    7
    well its up for 1700! but i already know im giving him no more than 1400-1500. Ill give him a ring later.
    tracer's Avatar
    '96 a4 1.8 se
    Oct 2005
    scotland
    266
    just make sure you drive it yourself ,then you will get a feel for any problems . be overly critical now, it will save you in the long run. if you are running a passat at the moment you already have a good benchmark to go by.
