Chris NottVolks Autos
Results 1 to 15 of 15
    audivro's Avatar
    Apr 2008
    36
    New to the forum,have a clutch question.
    Hi,have been looking for an informative forum and have definately hit on a good one.
    Anywhoo,i have a 96 b5 1.8t that probably could do with a new clutch and have been told that a vr6 unit is a direct fit?Presuming this to be the case is it going to provide a better clamping pressure?Being a tech by trade; fitment isn't an issue but want to make sure it is do'able.
    Also on this note i have read threads that these are fitted with a dmf!!If this is the case is there a solid unit from the vag range that will fit?
    Many thanks in advance.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,354
    I dont believ the VR6 pressure plate will fit,and i have seen some conversion kits for various VAG models that convert to a single mass FW.
    After lots of homework, i went for a SPEC stage 3 clutch and LWFW @ 16 lbs instead of 26lb for the OE one.
    audivro's Avatar
    Apr 2008
    36
    Thanks for the reply mate,Would that be a lightened dmf or solid fw.
    Apr 2004
    12,354
    Mine is a solid, with a sprung friction plate. Doesnt chatter noticably, i am sure if it were lighter it would chatter like a nudists teeth in the arctic
    audivro's Avatar
    Apr 2008
    36
    lol,may i ask where it was from?Thanks again
    Apr 2004
    12,354
    Ebay, Most of my car came from there one way or another.lol
    The whole kit cost me 250/300 imported from the US as the supplier put it down as a warrenty replacement
    Oct 2007
    2,597
    VR6 clutch WON'T fit - (who said it would??)
    VR6 clutch is 228mm, 1.8T is 240mm.
    audivro's Avatar
    Apr 2008
    36
    hi siena,thanks for the pm will contact you asap,as for the info please see the link.Thanks for the reply's guys.
    http://www.pitt.edu/~vek1/VALSITE/Cl...ClutchInfo.htm
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    the QH catalog seems to suggest the A4 1.8T has a 228mm clutch? Some V6's have 240mm and others have 228mm too?
    Oct 2007
    2,597
    All VR6 12V have 228mm clutch, including Syncro models.
    All 1.8T clutches I've fitted have been 240mm.
    "Stick a V8 in it!"
    14,900
    https://sslrelay.com/buypartsby.co.u...p?recordID=343
    https://sslrelay.com/buypartsby.co.u...p?recordID=345
    They also back up what QH say and recon 1.8T's have 228mm clutches?
    Apr 2004
    12,354
    My old OE one was 228mm ^^^
    Oct 2007
    2,597
    Mark, your car was originally a 1.8 SE.
    Oct 2007
    2,597
    Just checked - there ARE 228 and 240mm clutches fitted to 1.8T.
    Curious.
    Apr 2004
    12,354
    Yeah, that clutch was from my 1.8t engine/flywheel. Before i put the stage 3 on.
    So it was a 1.8t clutch, IIRC the same as the OE 1.8se one.
    Bloody cars
