EM TuningJMB Retrofits
Page 18 of 21 FirstFirst ... 81112131415161718192021 LastLast
Results 681 to 720 of 820
  1. #681
    Lee Goodall's Avatar
    ..got my head together!
    Oct 2007
    UK - Midlands
    2,223
    better hurry up and fetch the oil return, i'll be down in a couple of weeks to steal your turbo, streight from the engine bay if i have to. :P
    You can fit my Garrett too while you're there
  3. #682
    Dec 2006
    131
    Quote Originally Posted by Lee Goodall View Post
    A very similar setup to mine then although your exhaust is 1/2" larger in diameter. You running a CAT?
    Chop chop then get it mapped so that I've got something to work towards lol.
    nah no cat, f reg so i don't need it :D
  4. #683
    Dec 2006
    131
  5. #684
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,389
    Sure, you just need to stick to the appointment next time :P
    Need to work out when we're free to get it sorted.
    TD5 Land Rover Defender build
  6. #685
    Oct 2007
    UK - Midlands
    2,223
    Quote Originally Posted by sam80quattro View Post
    Oh yeah, I forgot yours is an 80. Lucky!
  7. #686
    Oct 2007
    UK - Midlands
    2,223
    Yeah, I'll get the drain sorted asap and we can sort something out.
  8. #687
    Oct 2007
    UK - Midlands
    2,223
    Some progress.. I used my spare green R&D A4 (lol) to get the T28 turbo and any components that I am particularly concerned about installed.
    The turbo was previously removed so this gave me a head start.
    Air box removed.
    Garrett and T25 flanged high flow manifold (cable tied together to save time)
    Old manifold removed.
    Garrett and new manifold bolted in.
    Oil feed and drain (drain not visible) in place.
    Silicone hoses from turbo outlet to FMIC in place (no FMIC fitted on this car).
    Turbo inlet adapter collar fitted ready to take 63mm diameter hose.
    Huuuuuuuuge Green Cotton air filter, MAF and silicone intake hoses in place. I'm missing a 90 degree reducer which will replace the two hoses leading to the MAF.
    All in all I'm pleased and now confident that it should all bolt into place without too much trouble. The six nuts on the top/centre of the exhaust manifold are nearly impossible to tighten with any kind of socket/tool so this may require some thought.
    Controversially I will be opting for an atmospheric dump valve as this will simplify things massively. I have run one on an AEB before with no issues at all. I will fit it to the cold side of the engine between the FMIC and the throttle body.
  9. #688
    "Stick a V8 in it!"
    15,389
    Ah some progress at last!
    Whens it going in the purple car then!?
    Make sure your DV is a twin piston type like the bailey dv26 for minimal issues.
    Some of them sit open when the engines pulling a vaccum.
  10. #689
    Oct 2007
    UK - Midlands
    2,223
    MOT at the end of this month so when that's out of the way I'll get all fitted.
    Yeah I'll make sure it's a twin piston dump valve. Cheers.
  11. #690
    jcb
    Sep 2005
    uk
    4,077
    looking good.
    heat shield in order?
  12. #691
    Oct 2007
    UK - Midlands
    2,223
    No heat shield planned to be honest. I'm figuring that the only time that it'll be sucking in any warm air is when I'm stationary. When I'm moving there should be plenty of cool air flowing around the turbo.
    How's yours coming on?
  13. #692
    Oct 2007
    UK - Midlands
    2,223
    The second to to last part for the conversion was delivered today, it's a Forge dual piston ram dump valve. The dump valve came with a service kit and I already have a yellow spring to replace the standard green one with.
    Just waiting for a replacement oil feed adapter from Earl's Performance Products that should have been with me this week but is out of stock until early next week.
    The turbo will definitely be fitted and running for GTI International (25th - 26th June) although finding somebody to tune it is proving to be hard work
  14. #693
    Oct 2007
    UK - Midlands
    2,223
    MOT in 1 hour
    Please think positive thoughts for me!
  15. #694
    "Stick a V8 in it!"
    15,389
    Should be reet! I've never had a car fail a test yet. Anyone that works on their car often will know the car well enough to ensure everythings fixed before the MOT anyway!
  16. #695
    Oct 2007
    UK - Midlands
    2,223
    Passed front tyres are on the limit (but I knew about that) that's all
    I've got a fairly bad coolant leak on the turbo side. I had the car jacked up last night and didn't notice anything; I hope it's nothing too painful!
  17. #696
    "Stick a V8 in it!"
    15,389
    Best get that old turbo removed then eh?
  18. #697
    Oct 2007
    UK - Midlands
    2,223
    You want me to bring it to Inters?
  19. #698
    Oct 2007
    UK - Midlands
    2,223
    So it appears that the gasket that seals the coolant pipe going into the back of the head (with the coolant sender/sensor in) is leaking. Ideally I would like to replace this when I do the turbo as I will be draining the coolant anyway. The turbo will hopefully be fitted the weekend after next so is it safe to drive if I keep it topped up and keep an eye on the engine and coolant temps?
  20. #699
    "Stick a V8 in it!"
    15,389
    Inters could be good
    Should be fine, as you say keep an eye on it. Its just a rubber o-ring. I assume your water level sensor is functional so you'll get a warning if it actually gets low?
  21. #700
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    That O ring is like 20p, i have had 2 on mine,lol
    Well done on the MOT etc
  22. #701
    Oct 2007
    UK - Midlands
    2,223
    I'm going to keep a close eye on the coolant and sort it with the turbo next weekend. Has anybody got the part numbers for the O-ring and two allen bolts for the coolant connection to the head?
    In order for the TIP to fit without chafing I could do with removing this section of metal/lip.. do you think this will be safe/won't cause any weakness?
  23. #702
    Apr 2004
    12,523
    wel if you dont grind past the spot welds, you should be fine strength wise. but tbh what little differenc it makes, i can't see the harm in removing it completly as if that little bit was to bend in a crash, you have more to worry about than a slight weakness.lol
  24. #703
    Oct 2007
    UK - Midlands
    2,223
    Ha ha yeah good point. It's actually a smaller section than I've indicated on the picture but it will need to be flush or I'd imagine it'll cut through the hose before too long.
    Am I ok to pay you a visit for some clutch action sometime after Inters?
  25. #704
    Apr 2004
    12,523
    yeah mate, no worries. Before if you want, but needs to ideally be a weekend. I just hope the slipping hasn't lipped the FW too much, will have to see i spose, not much else we can do is there? LOL
  26. #705
    Oct 2007
    UK - Midlands
    2,223
    Quote Originally Posted by Byzan A4 View Post
    I'm really struggling for time before Inters so it'll have to be after unfortunately. A weekend is best for me too. I haven't been driving on the limit because of the clutch to be honest and have only noticed the clutch slipping a few times when I've got a bit heavy footed so hopefully the FW will be fine.
    What other options would be economical? FW and S4 clutch etc?..
    Cheers mate
  27. #706
    Apr 2004
    12,523
    depends what you want mate. you could buy an std clutch kit and use the DMFW i have here worst case.
    I had my LWFW re surfaced and bought a sprung hubbed B6 friction plate and nailed that in mine, so far all good. Cost a few bears for re surfacing and £30 for the plate
  28. #707
    Oct 2007
    UK - Midlands
    2,223
    I want something that's definitely not going to start slipping. I'm aiming for 280 maybe 290HP so needs to have a fair bit of grab/clamp.
  29. #708
    May 2010
    Bedford
    2,877
    Could go with the ECS RS4/S4 clutch and flywheel combo or diesel solid fly and S2 clutch that im still wanting to get fitted
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
  30. #709
    "Stick a V8 in it!"
    15,389
    My solid flywheel turned up on wednesday (£30 delivered from ebay)
    Need to get myself a S2 clutch and find a shop to redrill it correctly!
  31. #710
    May 2010
    Bedford
    2,877
    Nice one! At this rate you`ll get it fitted before i do lol
  32. #711
    Oct 2007
    UK - Midlands
    2,223
    What cost are we talking?
  33. #712
    May 2010
    Bedford
    2,877
    Cheap for the flywheel from ebay or something. Clutch i got from GSF which retails at £189 plus vat i think although i got it cheaper. Only thing is they`re out of stock at the minute. The you just have to get it machined and redrilled would be about 70-90quid depending on where you go. Everything is in my thread a few pages back now.
  34. #713
    Oct 2007
    UK - Midlands
    2,223
    Quote Originally Posted by Jason.s View Post
    Hmmmm definitely something to consider then. Cheers.
  35. #714
    "Stick a V8 in it!"
    15,389
    Since i'm ghetto, i've baught a used flywheel, which i'll have skimmed and redrilled.
    I also went looking for a clutch and the S2 one was out of stock at GSF so started looking for alternatives. Sachs sell the cover and disk seperately for the S2, but i noticed on the sachs catalog that the cover was also used on a VW LT 2.8TDI van, and happened across a new Sachs clutch kit on ebay for £50 for said van, so i snapped that up.
    Finding the friction plate was a bit more difficult, but i've taken a punt on a random 240mm disk from ebay which was claimed to be from an A4 2.8 V6, and only cost £35. Most A4 clutches have a solid clutch plate, as they use the DMF to provide springyness, which obviously doesnt work on a Solid flywheel. Oddly enough, this clutch was listed for a A4 V6, but has a sprung hub, not entirely sure why, but i'm hoping it will work!
    I just need to get the flywheel suitably redrilled. I'll be taking it to the machine shop as soon as the cover plate arrives.
  36. #715
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    Is the s4 clutch disk not sprung?
  37. #716
    gmx
    Feb 2009
    Sydney
    133
    Looking good Lee,
    These look like a good bit of kit!
    I'm guessing it's a 2" diameter at least at the discharge?
    Who manufactures them or where can you pick 'em up?
    edit: or is that the kit pictured in post #671? Is it a custom pieced together kit?
    00 A4 1.8TQS GP MT AJL
    JHM SSK | FX300 + 16lbs FW | Milltek Dump back
    17*8 BBS RK | Deka ETX20L | Vogtland GT 575F/675R | H-Sport 35mm(F)/22.5mm(R) ARBs
    034 Engine Mts | Stern Snub/ Rear Diff Insert/Power Ring
    GT2871R Elim | Custom ME5 | 034 3" DP | 034 HFM | 034 TIP | ER Comp IC
  38. #717
    Oct 2007
    UK - Midlands
    2,223
    Cheers, it's all coming together nicely now (I think/hope)..
    The intake adapter is 2 1/2" and is from GB Enterprises - Welcome to GB Enterprises!
    The outlet is the standard 2" Garrett outlet (when fitted to the Nissan SR20DET engine) and I have used various silicone hoses to route it to the FMIC connection. I will be inserting a barbed connection into one of these hoses too for the N75 boost connection.
    The outlet can be seem more clearly on the pic below..
  39. #718
    Oct 2007
    UK - Midlands
    2,223
    Oh yeah.. The turbo intake adapter is pictured in post #664 along with an oil drain connection.
  40. #719
    Oct 2007
    UK - Midlands
    2,223
    Got these Mikalor W2 hose clamps today for the new boost connections..
    I'm all set to install the turbo over the weekend now.
  41. #720
    "Stick a V8 in it!"
    15,389
    w00t!
Tags for this Thread
